Random Stalling Issue
Results 1 to 15 of 17
This is a discussion on Random Stalling Issue within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My WRX seems to have developed a random stall. It's an '06 with 21k on it. Within the last couple ...
    Registered User RollTideRex's Avatar
    Mar 2007
    Greensboro, NC
    My WRX seems to have developed a random stall. It's an '06 with 21k on it. Within the last couple of weeks, it has stalled while at idle a total of five times, including twice last night. Most of the time the car idles just fine. Sometimes, however, the idle speed drops down to around 250 rpms or so and then jumps up to 1750, then back to a more normal speed. There doesn't seem to be any warning as to when it does this. I took it to the dealership here in Raleigh this morning to have them look at it. They just called me a minute ago and told me that they couldn't replicate the issue. I'm just wondering if anybody here has had a similar issue or any clue that I could pass along to the dealer so that they can fix it.
    Hawk-Eye Alliance #127
    06 WRB WRX
    "I will say one thing. It is amazing how many drivers, even at the Formula One level, think that the brakes are for slowing the car down." -Mario Andretti
    Registered User 05wrx4U2nv's Avatar
    Apr 2006
    maryland
    Quote Originally Posted by RollTideRex View Post
    ummmm warranty work.dont even ask just take it to the dealer.
    silly peguin. pointless wings are for ricers!
    Quote Originally Posted by sleepy silver View Post
    heard there is an ecu out thats like the hondata but for subbys.
    Mar 2007
    Greensboro, NC
    Yeah, it's at the dealer now. It's all being taken care of under warranty. They just called me back saying that they found a similar issue on the mechanic site regarding the throttle management system. He said they ran the fix (which I'm assuming meant flashing the ECU) and it was ready for pickup. Unfortunately, since they couldn't reproduce the problem, I don't know if the issue is resolved or not.
    06 WRB WRX
    Registered User Pheonix Rising's Avatar
    Dec 2006
    Valparaiso, IN
    A buddy of mine has a 03 WRX wagon, and had the same problem. We checked everything, and it looked great. However, the only think we never bothered checking was intake box. If that is not securely fastened it will make your car have idle trouble, and even stall it.
    ...and if that isn't good enough....my Toyota Celica GT had the same problem.
    2004 JBP Subaru WRX Rollin On Konig Rims
    Blobeye Syndicate #13
    Boba Fett BrianH's Avatar
    Oct 2003
    Way up high.
    stock bov? If so then check for vac leaks of any kind.
    Mar 2007
    Greensboro, NC
    The car is bone stock so far as I know. The reflash apparently didn't do any good from what I can tell, given that the car stalled twice today. I'll go downstairs here in a little while and check the airbox. I suppose that the jerks at Jiffy Lube could have screwed that up when I got my oil changed. They seem to take great pride in that sort of thing. Anyway, I'll post up again regardless of what I find.
    06 WRB WRX
    Mar 2007
    Greensboro, NC
    UPDATE: I checked to make sure that the airbox was properly seated and all that. Went out driving and it stalled 3 more times on me. I'm still trying to see if I can find any sort of common thread. No luck thus far.
    06 WRB WRX
    Mar 2007
    Greensboro, NC
    Update
    I took it back to the dealer yesterday to have them take another look at it. As luck would have it, they finally managed to get it to stall, but the laptop didn't catch anything because it was rebooting or something (I didn't really catch this part). Anyway, the service manager decided that he really didn't like not being able to fix this, so he gave me a rental until they get it resolved. He said normally they don't give rentals over the weekend, but he would this time. Not sure if this is typical of Subie dealers, but I thought it was cool of him. Dealer was Southern States in Raleigh, btw. I'll update this again as soon as they find somthing.
    06 WRB WRX
    Jun 2007
    eprov rhode island
    ACTIVE VALVE CONTROL SYSTEM (AVCS) UNION SCREW FILTER. IF A ROUGH IDLE AND/OR RPM DOES NOT INCREASE SMOOTHLY THERE IS THE POSSIBILITY THAT THE UNION SCREW FILTER OF THE ACTIVE VALVE CONTROL SYSTEM (AVCS) COULD BE DAMAGED AFFECTING THE OIL ..............
    if they dont find anything tell them to check into that..ive seen one so bad that the car did actually stall..
    New England F4
    feel free to pm me with any questions..
    Registered User xMDxWRX's Avatar
    Jan 2006
    Towson MD
    I have had some idle issues, it will drop to ~500 then bounce to ~1500 but never stalled, well it did before but that was with a BOv but no more
    2004 VW GLI "Back In Boost "
    Quote Originally Posted by KanoWRX View Post
    well...IMO, or IMI (In My Imagination) WRX's/STi's are still better that Evo's...hands down...despise the facts.........
    Moderator
    Jul 2003
    Maryland
    Either a leak or possible a bad IAC?
    Jul 2006
    Your dealership is weird. When they gave me a courtesy car the only major stipulation in the papers I filled out was not to drive outside of a 200 mile radius of the dealership, which is pretty hard to do anyways.
    Mar 2007
    Greensboro, NC
    Quote Originally Posted by subarutech View Post
    This sounded good to me, so I took it to the tech at Southern States. He said that he would have checked this, except that they removed this part in the MY06 cars. He said that they were going to clean the throttle plate and return the car to me today. I'll see if they have any more insight when I go back this afternoon.
    Thanks for all the suggestions, guys. I certainly hope that they can work this out.
    06 WRB WRX
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    This might sound stupid.......But try using your second set of keys.
    I have an 06 WRX and I was having this odd no start situation when I put the key in the ignition. It would happen about 1-2 times a day where I would try to click it over a dozen times or so to no avail. For some reason when I would get down and manually actuate the clutch limit switches with my hand then try the key it would start. This went on for a month or more and the subi dealer couldn't find anything.
    Finally I swapped out keys just in case there was a built in security comp chip (resistor) or something similar to what GM has that was malfunctioning. It has been a whole week with no delayed starts or failure to starts.
    Might be worth a shot and its free.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    Registered User Truckster27's Avatar
    Mar 2006
    Everywhere
    Another thing that can lead to stalls is a dirty or mispositioned MAF sensor. Its in the intake right after the filter. its got 2 screws holding it in with a bunch of wires. This would cause your issues, possibly...
    Movn' on up to an '06 WRX
    Vf-39 all the way!
    Love to build 'em, just to ship 'em out and start all over!
    I got friends in cyberspace, so I must be cool, right?
    Facebook / Myspace
