checking oil
Page 1 of 3 123 LastLast
Results 1 to 15 of 45
This is a discussion on checking oil within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hi i am a new member i have recently purchased a 2001 subaru impreza wagon wrx, does anyone know what ...
    Jun 2007
    Question checking oil
    hi i am a new member i have recently purchased a 2001 subaru impreza wagon wrx, does anyone know what type of oil i should put in it and do you check the oil the same as any other car (do you leave it sitting cold to check dipstick?) cheers kaney
    Registered User pTx415's Avatar
    Feb 2007
    Bay Area, CA
    yes you do. check when its cold
    Feb 2007
    Bay Area, CA
    o yea. use Mobil 1 Synthetic oil
    Registered User xMDxWRX's Avatar
    Jan 2006
    Towson MD
    I let the car run for a little bit before checking the dip stick, let it run through for a minure or 2, but that may just be me
    2004 VW GLI "Back In Boost "
    Quote Originally Posted by KanoWRX View Post
    well...IMO, or IMI (In My Imagination) WRX's/STi's are still better that Evo's...hands down...despise the facts.........
    Registered User tom'sti's Avatar
    Feb 2007
    Reality
    Check it running, on a hill.
    Ok, really. It doesnt matter a huge bit warm or cold as long as its near the full mark. If it has been running, let it sit for a few minutes to let the oil drain back into the crankcase for an accurate read. FYI, the space between full and add is usually one quart.
    Whoever appeals to the law against his fellow man is either a fool or a coward. Whoever cannot take care of himself without that law is both. For a wounded man shall say to his assailant,"If I live, I will kill you. If i die, you are forgiven. " such is the rule of Honor.
    Feb 2007
    Bay Area, CA
    Quote Originally Posted by tom'sti View Post
    it does actually. you don't check it while its warm. For Example after you drove your car for a long time and shut it off, pull the dip stick. that will give you an inaccurate reading. its better cold.
    this is what i do when i change my oil. Change oil + filter, put in new oil, make sure everything is tight. Run the car for about 1 minute. shut it off, check the level.
    Feb 2007
    Reality
    Quote Originally Posted by pTx415 View Post
    Make sure you have someone else shut it off so you can pull the stick right when the crank stops turning, right?
    Jan 2006
    Towson MD
    When we are saying check it while its warm no one meant go run at the track on a 105 degree day then check it, i meant run it for a minute or 2 then check it
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    Quote Originally Posted by xMDxWRX View Post
    Nobody said it, but I will
    when I change my oil I put 4.5qts in, turn it on for a minute or 2 so the oil goes into the oil filter, then I top it off at full.
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Feb 2007
    Bay Area, CA
    okay.....
    well its implied! who knows what "warm" means to ppl. could be running for 1 hour, shut it off, and check it. btw. runing it for 1 minute, won't make it warm.
    Jun 2007
    chechking oil
    thanks 4 replies im sorted now new scooby owner just learning!!! cheers
    Jun 2007
    checking oil
    Registered User big_sur's Avatar
    Sep 2006
    Goode, VA
    well hang out here a bit longer and we'll get you unsorted
    May 2005
    Phillytown, PA
    Hot or cold it really makes no difference as long as the oil has had sufficient time to drain back into the pan. If you shut off the car after driving it and you immediately check the level, you will still have have oil that has yet to make it into the pan.
    Hence:
    Registered User powder's Avatar
    Aug 2006
    WA State
    Run it until your temp gauge gets to where it sits when you drive it. Go home and shut the car off and let sit for 5 mins. Then go check your oil level after all the oil has gone back into the pan.
    At that point it should be in between your 2 dots.
    FYI, oil expands when it heats up. If you fill it to 4.8 quarts cold, it will look like over 5.5 quarts warm. That's not good.
    Blobeye Syndicate #2004
    Military Militia #30-06
    2004 WRX - JBP:Stage 2:13.93 @ 96
    Wingless alas. Too bad it took a 50 ton truck to make it happen.
