Engine Light Rich Bank 1 P0172
Results 1 to 14 of 14
This is a discussion on Engine Light Rich Bank 1 P0172 within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; My 2002 WRX I've just bought has a check engine light on. It shows P0172 Running Rich Bank 1. No ...
    Jun 2007
    Houston Texas
    My 2002 WRX I've just bought has a check engine light on. It shows P0172 Running Rich Bank 1. No other faults indicated. I've replaced the O2 sensor, changed the spark plugs and replaced the gas cap lid and the light keeps coming on. The air filter looks dirty and it has a dirty APS Blow off valve, could either of these be causing my engine light? What should I check next? It has 78000 Miles and I've also just done an oil change....thanks for reading...
    Pretty sure it would be the BOV.. Everything I read on this forum leans towards not having a BOV .. at least not at basic power levels.
    Nov 2006
    Check your grounds, once I had a faulty ground that was throwing false CEL codes.
    Registered User 68sprintb's Avatar
    Dec 2005
    San Jose, CA
    Quote Originally Posted by ww_Crimson View Post
    +1 the BOV is going to cause a rich condition by nature, i haven't heard of it causing a P0172 code but it's possible
    Blobeye Syndicate #75
    2005 OBP WRX Sport Wagon
    Stewart Warner Boost & Oil temp gauges / OEM 20 mm rear bar
    Cobb stg 2 / STi uppipe / Crucial Racing downpipe
    Stromung 2.5" catless centerpipe / ScoobySport New Age centre pipe & backbox
    Jun 2007
    Houston Texas
    My car also has a aftermarket cone filter which I've read may cause that code. I'm wondering if maybe a BOV that's way out of adjustment may cause an excessive rich condition. I've thought that the one on my car may have the adjustment screw backed out too far....Thanks for all the replies...
    Dec 2005
    San Jose, CA
    Quote Originally Posted by astropods View Post
    that could be it, Subaru's tend to be very sensitive to intake path modifications. If there is an adjustment screw, it's for setting boost pressure i think, has nothing to do with the mixture control.
    UnBanned Sinister's Avatar
    Nov 2006
    Denver Metro Area
    That's almost DEFINITELY the problem. The BOV will cause rich shifts, but I've never heard of it throwing a CEL. The cone filter (AEM especially!) are known for causing misreads in the MAF sensor. Revert back to stock, or buy a Cobb SF, K&N Typhoon, APS, or SPT and reset the ECU and you should be golden
    Kevin
    Moderator
    Sinister's Blowoff Valve FAQ
    WRX Gas Mileage FAQ
    Firearms Enthusiasts Thread
    Jun 2007
    Houston Texas
    Solved
    Well, I replaced the BOV and it didn't change the way the car ran at all. I was still getting CEL and misfires. Well the other day I found that the car was running almost perfect without the ac on. So I clicked the fan on and turned the ac off and on but it still ran badly. I clicked off the fan and boom, only very slight misfire. Turned off the fog lights and the misfire goes away almost completely. So when I run simple electric stuff it takes power from the ignition = bad spark/run rich/misfire. So, is it the alternator or a short? I know I can test to see but maybe someone else has had this before. Man it runs good with everything off.....
    Nov 2006
    Denver Metro Area
    Have you tried the most basic steps of reseting your ecu, and checking your fuses? ( always do these first w/ an electrical problem )
    Then take your baby down to autozone and have them do their free electrical testing on her.
    Is there any corrosion on your batt contact points? (I had a similar problem w/o misfires in my truck. The truck ran poorly w/ electrical equip on, I replaced the contacts and it was fine)
    Are there any other noises coming from the engine compartment besides the misfires?
    Kevin
    Moderator
    WRX Gas Mileage FAQ
    Jun 2007
    Houston Texas
    Yeah, I reset the ECU a few times. No other strange noises except for that it turns over a little slow when I start but it's never not turned over. Battery points are fine but there is an intercooler spray system ala sti installed that added a second motor to the windshield washer system that seems to be wired pretty badly. I'm going to disconnect it and go to the autozone and have them check it out. If it runs well over there then I guess that's the problem. Thanks for your help....
    Nov 2006
    Denver Metro Area
    Good luck bro
    Kevin
    Moderator
    WRX Gas Mileage FAQ
    Sep 2008
    Po172
    i have a problem, i have a 2004 subaru wrx, its been giving me problems with the p0172, ive change spark plugs, ive changed the intake sensor, also changed the sensor where by turbo, and yet its still giving me this code any body know
    Is in Love With the Admins Here 20WRX04's Avatar
    Nov 2004
    WNY
    Quote Originally Posted by larry_ru View Post
    Welcome. Way to threadjack. Did you try searching the site? What mods do you have?
    The first rule of the Faction is...DO NOT TALK ABOUT THE FACTION.
    NY GIANTS
    Hybrid Faction #19
    Blobeye Syndicate #19
    Mods
    any body know
    Full list of modifications.
    EDIT: Never mind; deja vu all over again... See here:
    P0172 help!!!!!
    Post back if those steps don't solve it.
