Loosing Pwer
Results 1 to 12 of 12
This is a discussion on Loosing Pwer within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi guys I am losing power to the car as the fuel gets below the half mark, then it will ...
    Jun 2007
    Loosing Pwer
    Hi guys
    I am losing power to the car as the fuel gets below the half mark, then it will have poor performance until i fill up again. Why does this happen?
    Nov 2005
    Central Florida
    what r u using to measure this performance loss ?
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Jun 2007
    Dont use anything, I can feel it, it just doesnt have that pull away when the fuel is below the half mark, it is like not pushing through enough petrol...
    Nov 2005
    Central Florida
    i dont see how this is possible
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Nov 2005
    Central Florida
    wrx/sti fuel tank hold "13.5 gallons" of fuel not including the reserve
    1 gallon of water weighs 8 lbs
    13.5 x 8 = 108 lbs @ full tank
    6.75 is half of a tank of gas
    6.75 x 8 = 54lbs @ half tank
    u would be gaining hp by having less fuel
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Nov 2005
    Central Florida
    heat soak might be ur problem
    Originally Posted by garin
    can somebody please explain to me what heat soak is? i tried to search for it but found nothing.
    Quote:
    While TMICs' offer a fix to the "turbo lag" caused by the FMIC, they experience an effect known as "heat soak", where the heat from the engine warms the intercooler, lowering its efficiency to cool the intake charge. Due to limited room in the engine bay, TMICs' tend to be small, and can only efficiently cool small amounts of air. At high horsepower levels, or when using large turbochargers, FMIC's are much more efficient than TMICs
    from here:
    http://en.wikipedia.org/wiki/Intercooler
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Registered User se7en's Avatar
    May 2007
    Southern California
    Quote Originally Posted by rr1911 View Post
    +1
    "A man that buys a Corvette has a mid-life crisis, but a man that buys a Lambourghini has NO crisis." -Rev Run
    Registered User SubyPsycho's Avatar
    PA
    I'm with you on this. I don't see how it's possible. If he were having a fuel flow problem, I would expect the ecu to throw a cel because it has sensors to detect that kind of thing. It can even indirectly detect a fuel flow problem by the a/f ratio. Less fuel would mean a higher a/f ratio, which would increase exhaust temps, cause potential misfiring, and all kinds of other issues.
    Registered User Mike502's Avatar
    Apr 2007
    Tappahannock VA
    Quote Originally Posted by Bertus View Post
    Hi guys
    Sounds to me like you one of 2 problems (or both)
    either you have an classic case of the automotive gremlin
    or...You need to have someone else drive the car and see if they experience the same thing...It may be a figment the imagination
    Peter: Oh my god, Brian, there's a message in my Alphabits. It says, 'Oooooo.'
    Brian: Peter, those are Cheerios.
    Registered User ScoobVee's Avatar
    Mar 2004
    how many miles do you have on it?
    Thats not possible, his power to weight ratio would slightly increase but not enough to feel from seat of pants
    - Local Riceist
    Oct 2005
    Ocean Grove, NJ
    Cold fuel is good fuel
    What are your driving habits compared to your refueling habits. If you are running it down, then filling it up - the fuel coming out of the ground is going to naturally be much cooler than ambient air more often than not (unless you live in a cold area).
    PA
    Quote Originally Posted by Micah View Post
    Is that even enough to make a difference though? I would suspect it would be such a small difference that the added weight of the additional fuel would cancel it out.
