cooling system/radiator concern
Results 1 to 8 of 8
This is a discussion on cooling system/radiator concern within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; im kinda new to these sweet machines... but my concern is the following: on the radiators, across from the coolant ...
    Registered User InfernoAWD's Avatar
    Mar 2007
    im kinda new to these sweet machines... but my concern is the following: on the radiators, across from the coolant resevoir tank there is a small rubber kinda opening... im guessing it lets the pressure out (this looks attached to the radiator)... but i have seen coolant come out of it... is this normal... the stupid thing is that the reservoir tank is overfilled... does this have anything to do with the coolant shooting or coming out of that valve, or pressure releasing thing? is this something i should be worried about??? sorry for the ignorance and any inputs would be greatly appreciated... again is a valve/pressure releasing thing on the right side of the radiator by the coolant reservoir... cuz i have dry coolant around those parts including the battery and radiator... thanks again
    flies like a butterfly, stings like when i pee
    Oct 2004
    Westchester Cnty, NY
    Quote Originally Posted by InfernoAWD View Post
    No you should not have coolant coming out of anything. Can you take pics of the areas in question? Do you mean that the hose going from the resevoir to your Turbo is unplugged? Worst case, go to your Dealer and have it fixed.
    2015 Plasma Green Pearl XV Crosstrek Hybrid Touring
    2011 Lightning Red WRX LTD Sedan w/ Nav (returned)
    2008 Lightning Red WRX Prem. Hatch w/ Nav (returned)
    2005 San Remo Red WRX Prem. Sedan w/ VF34 (traded)
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Yeah the coolant is a closed system. Take pics and post
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    Mar 2007
    I feel so stupid... i should have checked before acutally asking... i found a small crack on the upper part of the radiator sorrounding that valve(on the radiator) by the coolant reservoir tank... do you guys think is of to use a plastic weld or some other type of sealant as a temporary fix... or should i just replace the entire radiator? again is a supper small leak causing almost no excessive loss of coolant... thanks guys
    If what you are seeing is a crack in the plastic upper tank of the radiator itself, you're done with that radiator. Post a picture if you can and we'll tell you for sure. Or, search for engine pay pictures here, "steal" one of those, and put a red arrow or something where the crack on yours is etc.
    Mar 2007
    hopefully the picture works... the engine bay is not mine of course (i wish) the crack is located right on the tube where the arrow points, the crack is located on the base of the tube or valve where the arrow points the crack does not go around it but it goes horizontally for about an inch... the crack is very small, i had to look hard for it and cause little or almost no coolant loss... again is it cool if i use a sealant temporarily? the leak is under the rubber ring.
    So the crack is not on the radiator itself, but on the solid part of the tube connecting the radiator to the overflow reservoir? Is the crack on the tube at a location where you can simply slide a longer hose over it, clamp the end, and be done with it?
    If I understand the photo correctly, that part of the system is not pressurized. There is a diaphragm that controls overflow once a certain pressure is exceeded, and the coolant is allowed to escape to the overflow reservoir (white plastic container on driver's side front; to the right of your photo). If the leak is anywhere along the coolant escape route, there will not be coolant running through at all times (only when the system is venting coolant to the overflow tank, or drawing coolant from the overlow tank).
    If I'm on the same page as you then see if you can just use a longer hose to cover the leaking area. Also try to figure out how you managed to get a crack there, it's not easy to imagine unless something hit it (wrench or hood prop rod or something).
    Jun 2006
    Nor Cal
    Yeah its new radiator time. The radiator is an abs plastic derivative and doesn't take well to adhesives. Buy a new one.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
