headlight problem
Results 1 to 5 of 5
This is a discussion on headlight problem within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 2002 wrx. My passenger side light is not working. I must have crossed wires while replacing the ...
    Nov 2006
    York, PA
    headlight problem
    I have a 2002 wrx. My passenger side light is not working. I must have crossed wires while replacing the wire harness. Now even with my new light bulb and wire harness the light is very dim. Also my high beam indicator is not working when I turn on the high beams. Did I blow a fuse somewhere? I tried switching the wires around and nothing.
    Registered User Truckster27's Avatar
    Mar 2006
    Everywhere
    Sounds like your not making a good ground....check the black? wire I believe (should bolt into the metal frame somewhere). That will cause you to go dim and lose high beams...
    Movn' on up to an '06 WRX
    Vf-39 all the way!
    Love to build 'em, just to ship 'em out and start all over!
    I got friends in cyberspace, so I must be cool, right?
    Facebook / Myspace
    Administrator
    May 2003
    Like stated above, bad ground.
    Mace Windu devilfluff's Avatar
    Feb 2005
    south jersey
    Quote Originally Posted by transfan0186 View Post
    Make sure the ground connection is tight first and check the fuses. I had the same problem and ended up w/ both a loose connection and a blown fuse.
    Dirty Jersey
    Part-Time Grammar Nazi
    RIP- '02 PSM Wagon
    SOLD- 08 Candy White MK5 GTI 6spd
    '15 WRB BRZ Limited, 6spd
    Moderator:Tri-State and Transmission & AWD forums
    Registered User anthonywrx's Avatar
    Feb 2004
    Elk Grove, IL
    Quote Originally Posted by psb02wrx
    while you carpe diem, tell her to carpe deez nuts.
    Fun In the Snow
    STi in the making...
