low idle
Results 1 to 11 of 11
This is a discussion on low idle within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i have a 2001 with low idle speed. does this indicate a larger problem or can i just set the ...
    May 2007
    low idle
    i have a 2001 with low idle speed. does this indicate a larger problem or can i just set the idle up?
    Administrator
    May 2003
    Quote Originally Posted by hilld View Post
    We didn't get a 2001 here, so you must be overseas. What is it idling at?
    May 2007
    low idle
    the idle jumps up to 1000 and it runs fine but sometimes at a stop light it drops to 600 RPMs. it normally runs at around 800
    Nov 2005
    Central Florida
    how long has it been doing this ?
    also does this only happen with the ac on ?
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Banned for Ageism 96accord's Avatar
    Mar 2007
    Baltimore, Maryland
    Welcome to the Club!
    Apr 2004
    Southeastern PA
    Greetings and welcome to the club!
    Moving to General Maintenance, Troubleshooting & Tutorials
    Mods & Pics
    May 2007
    low idle
    i just bought the car. when i bought it, it was not having this problem. i had the streering rack and an axle changed and now it is having a problem with the idle. i had the idle control valve changed yesterday and the idle still seems low to me. however, it is not cuting out at the stop sign. it idles poorly with the ac on or off. it idles fine in neutral.
    djh
    Registered User 68sprintb's Avatar
    Dec 2005
    San Jose, CA
    do you have any experience using a DMM? you could check it yourself as the idle actuator is usually easy to get to.
    Blobeye Syndicate #75
    2005 OBP WRX Sport Wagon
    Stewart Warner Boost & Oil temp gauges / OEM 20 mm rear bar
    Cobb stg 2 / STi uppipe / Crucial Racing downpipe
    Stromung 2.5" catless centerpipe / ScoobySport New Age centre pipe & backbox
    May 2007
    i have the same problem with 02 wrx and i dont no what to do, mine idles at around 500 my friend's mr2 was doing the same and some mechanic just tightened a spring and it was fixed can u do that to wrx's as well?
    May 2007
    low idle
    yes i know how to use a DMM. i do not know what or where to check.
    i don't know anything about a spring. as you can see, i am not much of a mechanic when it comes to Subaru's. this is my first one. i am sure i will get better.
    djh
    Dec 2005
    San Jose, CA
    djh
    i've done it before on my 05 WRX, but it's probably similar to yours. anyway here ya go:
    you're looking for the IAC motor right on top of the throttle body. it'll have 3 wires going to it, you want the white one. gently insert a pin into the connector (still connected) at the white wire from the back and push it till you feel it hit metal and stop.
    then connect the black lead of the DMM to ground, and the red lead to the pin in the connector on the white wire. with the DMM set to VDC it should read 9-10 VDC at a hot idle. if you have it, use the dutycycle signal triggered low and it'll read about 30%.
    if that doesn't match, the IAC is typically attached to the throttle body and easy to see. attach a pic if you can, and we can go from there.
