possible oil leak with pics (56kwarning)?
Results 1 to 15 of 15
This is a discussion on possible oil leak with pics (56kwarning)? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hey guys i was changin my oil yesterday and while doing so i noticed what looked like oil leaking around ...
    kmo
    kmo is offline
    Dec 2006
    nova
    hey guys i was changin my oil yesterday and while doing so i noticed what looked like oil leaking around the seals of some part of the motor. Im not sure which part of the motor it is so i took a pic. Hopefully you gguys can tell me what it is and if its something to be concerned about or not. Thanks. PS i dont no how to resize pictures so sorry its so big.
    ...We Are Virginia Tech...
    Proud to be a Hokie 3-16-07
    Registered User SubyPsycho's Avatar
    PA
    Can you reach your finger to it and see if the oil is still wet? If it's dry, it might just be a discoloration from heat.
    kmo
    kmo is offline
    Dec 2006
    nova
    Quote Originally Posted by SubyPsycho View Post
    it was def wet and that was the most wet part but i could see oil traces along where the metal and plastic parts connected continuing down as well
    PA
    That's not good. Can you take a pic from further back so I can see where in the engine bay it is? It's hard to get a reference point from the first pic.
    kmo
    kmo is offline
    Dec 2006
    nova
    heres a pic the thin green line is where i see the leak
    kmo
    kmo is offline
    Dec 2006
    nova
    neone???
    Registered User devarian's Avatar
    Sep 2006
    Sumter SC
    i would like to say that i think it is your valve cover gasket. reason being my engine is out and thats where i thought mine was leaking. but my ended up being the cam seals.
    PA
    Valve covers is a definite possibility. I was even thinking that it could just be from the oil filter. The oil could be leaking there and then running to the bolt that appears oily.
    kmo
    kmo is offline
    Dec 2006
    nova
    is valve covers a serious problem? how costly of a repair would that be?
    Registered User tom'sti's Avatar
    Feb 2007
    Reality
    I agree, looks to be coming out from behind the timing cover, so cam seals are likely, possibly valve cover.
    Whoever appeals to the law against his fellow man is either a fool or a coward. Whoever cannot take care of himself without that law is both. For a wounded man shall say to his assailant,"If I live, I will kill you. If i die, you are forgiven. " such is the rule of Honor.
    kmo
    kmo is offline
    Dec 2006
    nova
    is the a serious issue? what can it cause.... is there a way i can test these theories like maybe a compression test or something. And how much do these things generally cost to get fixed?
    Feb 2007
    Reality
    Quote Originally Posted by kmo View Post
    The only sure fire way to confirm an oil leak is to view it directly. If its a valve cover leak, may not be so bad. If its a cam seal, may not be so bad. The problem with cam seals is, when severe enough(which your isnt) and it starts to saturate the belt, bad thing begin to happen which ends in broke motors. Not to scare you, this is of course way worst case. Aside from that, no minor oil leak is damaging as long as you check and correct the level regularly. I'm pretty sure it has to be either one of these, so i'd but all cam seals and valve cover gaskets needed, tear into it and just return what you dont need. Since you may have it off, it would be a good time for a t-belt.
    kmo
    kmo is offline
    Dec 2006
    nova
    Quote Originally Posted by tom'sti View Post
    Well im ive never really done any serious work on my car. It sounds like a difficult thing to do for someone like me but maybe not. Any idea as to how much it would cost to get fixed as opposed to doing it myself. Im worried that would be too difficult for me.
    Feb 2007
    Reality
    Sorry, no. I just work on cars, i dont have anything to do with pricing. To do a cam seal should'nt be much more labor than doing a t-belt. Call around and get quotes and remember, the dealers DO know your car best.
    Jun 2007
    eprov rhode island
    ok first off ive been a subie tech for 8 years..and what you have is a cam seal leaking issue..for sure..without a doubt.. i recomend repairing them because oil will compromize your timing belt..i also recomend doing all 4 cam seals at once ,and the oil pump seal..your gonna need special tools to pull the cam gears that love to break thanks to their plastic like design.. id also check your timing belt tensioner for oil around the hydraulic piston of it..if oil is present replace it while doing the seals.. but yes your prob is cam seals and im sure of it... hope i helped
