Might need reflash, 07 STi...maybe?
Results 1 to 9 of 9
This is a discussion on Might need reflash, 07 STi...maybe? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I've heard a lot about the 07 STi's needing an ECU reflash...what are the symptoms of the car? I'm getting ...
    Registered User Jtek's Avatar
    Oct 2001
    Massachusetts
    I'm getting this sputtering from the turbo around 3K.
    In time people will see who you truly are.
    2007 Urban Grey Metallic Subaru Impreza WRX STi. Hawkeye Alliance #71
    Moderator
    Jul 2003
    Maryland
    Second thread on the flash in two days. I made a rather lengthy post in the other one if you search for it.
    Cliff Notes: The flash usually only fixes the issue for a tank of gas or two and it comes back. Gabe has a free enginuty map that fixes it. Subaru hasnt released a "real" fix for the issue. The issue is the car isnt going into OL as it should. It wont go into OL until you are past 4,400 rpms or above 80 mph. This is the hestiation you feel.
    Either get a tactrix and flash or get an AP and flash. Those are really the only fixes as of yet. Subaru probaly wont release a fix because they probaly cant due to emissions.
    The issue everyone complains about is hestiation between 3-4k rpms. It should feel "jerky" and not "smooth" when getting on it.
    May 2007
    Queens,NY
    are u serious, i got a 07 sti. Is this happening to all the 07s? subaru should recall the problem because it sounds like the turbo will blow.
    Moderator
    Jul 2003
    Maryland
    Quote Originally Posted by MR2fastn2fine View Post
    No not serious at all
    The turbo should be the least of the worrys. With the car boosting in CL you'd risk detnation and possible destroying the motor (the car will pull timing and cut power probaly before the motor goes).
    None the less Subaru has issued a "fix" for it that doesnt really fix it. They apparently cant fix it (or dont want to ) due to emissions.
    Luckily there are several options to fix it on your own. Search Nasioc for "gabedude" as he has a free map you can flash or get an AP.
    It's not with EVERY STI just 90% of them. If you use the same high quality gas over and over the ECU will probaly run on it's aggresive map other then the crappy one. The thing is if you go out of town and get some lesser quality gas it'll start to have problems (Like mine did this week).
    Oct 2001
    Massachusetts
    Quote Originally Posted by 302@12psi View Post
    So if we stick to 93 octane from the same place it should cancel out the problem? Good job subie
    Apr 2007
    Queens
    I own an '07 wrx sports wagon and yesterday the CEL was on steady and cruiser light was blinking.
    I took it to the service center this morning and they told me i have a misfire on cylinder 1 and 2!
    I only have 1800 miles on my baby and this sh*t is happening.
    The service center couldn't work on it since they only handle oil changes n stuff on Saturdays. Anyone know what are possible causes of this misfire?
    Moderator
    Jul 2003
    Maryland
    Quote Originally Posted by Mr Wagonboost View Post
    Misfires could be anything really. Could be a bad coil, bad gas, bad plugs etc.
    Moderator
    Jul 2003
    Maryland
    Quote Originally Posted by Jtek View Post
    Yeah this is one theory and it worked fine for me. My car wasnt nearly as bad as it was when I was filling up up at the same station over and over. I was out of town and had to grab some other gas (still 93 but different station) and it started acting all kinds of funny. It's finally get back to how it was before.
    Apr 2007
    Queens
    Dude...I totally filled up at a different Mobil with the usual 93+ octane. After a good 50+ miles of driving is when I noticed the CEL. It drove pretty sh*tty for the rest of the day, especially with the a/c on. I was pretty low on gas by the end of the night and filled up a little at my usual Mobil and parked the suby.
    Next morning, I was driving it to the service center and it drove a little bit better. Maybe the "better" gas was curing the misfire? I hope.
