after crash no power to the fuel pump
Results 1 to 11 of 11
This is a discussion on after crash no power to the fuel pump within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i got a 2002 wrx i bought it crashed i just got it fixed but i put everything on ans ...
    May 2007
    i got a 2002 wrx i bought it crashed i just got it fixed but i put everything on ans squirted some oil in the sylinders. the whole nine to do when a car sits a while then i sprayed some starter fluid in the intake manifold i cranked it it started then shut off when the fluid was gone then i kept cranking it i pulled the fuel lines off they are dry i know cars have inertia switches but all data dont have nothing on subarus really what do i do?
    Registered User c00lbeans's Avatar
    May 2005
    Portland, OR
    Quote Originally Posted by quikcobra View Post
    sign up for English 101 at your local community college.
    May 2007
    already
    i just got on theis site and already **** talkers
    May 2005
    Portland, OR
    No ones going to help you if they can't read what you wrote.
    May 2007
    no power
    ok get this. i got the car it was wrecked i got it fix. ok heres more
    i cranked it (turned the key to start)
    it ran for a little bit(not long) b/c of the starter fluid i sprayed in the t-body
    then it stalled
    so i pulled the fuel lines off b/s i replaced them with better ones
    and they were drie there is no gas in the lines
    and no power to the fuel pump
    and i cant find any thing about a inertia switch on all data for a 2002 wrx
    May 2007
    **** it
    i fixed the problem althought subby's are a ***** to work on i figured it out and shes running like a champ
    Registered User xMDxWRX's Avatar
    Jan 2006
    Towson MD
    congrats
    2004 VW GLI "Back In Boost "
    Quote Originally Posted by KanoWRX View Post
    well...IMO, or IMI (In My Imagination) WRX's/STi's are still better that Evo's...hands down...despise the facts.........
    May 2007
    thanx
    thanx man with the new garrett turbo, hks full exhaust, and the 3" down pipe it sounded ****ing awesome so i think it was a 5000 great buy. but who can tune a utech in fl?
    and how is the utech there is a dial with 9 numbers on it how does this work? turbo xs dont have much about it
    Moderator
    Jul 2003
    Maryland
    Does the car have an inertia switch? It cuts the fuel pump off if the car is wrecked in most cases. Might have to reset that.
    Otherwise start at the fuel pump. Do you even hear the fuel pump? Is there gas in the tank? Then start following wires. Is the fuel pump rely blown?
    Administrator
    May 2003
    Quote Originally Posted by 302@12psi View Post
    The only cars I've run across with inertia switches are Fords.
    I used to mess with my friend years back. He would stop at the quickie mart and run inside quick. I would reach back and bang on the inertia switch, shutting the car off, and preventing it from starting again. He would freak out every time.
    Moderator
    Jul 2003
    Maryland
    Quote Originally Posted by Trainrex View Post
    I remember resetting my Mustang after a wreck so that was my first thought.
