Leaking oil pan. :-/
Results 1 to 7 of 7
This is a discussion on Leaking oil pan. :-/ within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So my oil pan needs diapers or something. It won't stop leaking. Very small leak, but still a leak. What ...
    Jan 2007
    Dirtee Jersee
    So my oil pan needs diapers or something. It won't stop leaking. Very small leak, but still a leak. What should i do?
    I almost feel like there's some obvious common sense answer to this but at 1:30 am common sense is pretty rare... :-)
    Registered User DeBlas66's Avatar
    Apr 2006
    Westchester, NY
    Quote Originally Posted by Blup View Post
    Is the bolt tight enough?
    Did it thread improperly?
    Is the oil maybe coming from the filter?
    Is that tight enough?
    Could it just be excess from your oil change dripping off?
    Car-less
    Administrator
    May 2003
    Common sense says to figure out where the leak is coming from and fix it.
    If it's coming from the crush washer, replace it.
    If it's coming from stripped threads in the drain pan, helicoil the plug or replace the pan.
    If it's coming from a crack in the pan, or a warped pan, replace the pan.
    If it's coming from the gasket, retorque, or replace the gasket.
    Registered User xMDxWRX's Avatar
    Jan 2006
    Towson MD
    Quote Originally Posted by Trainrex View Post
    Common sense FTW
    good luck with the problem
    2004 VW GLI "Back In Boost "
    Quote Originally Posted by KanoWRX View Post
    well...IMO, or IMI (In My Imagination) WRX's/STi's are still better that Evo's...hands down...despise the facts.........
    Boba Fett BrianH's Avatar
    Oct 2003
    Way up high.
    Is your dipstick blowing out as well by any chance?
    Registered User dcpatters's Avatar
    Sep 2004
    Irvine, CA
    Had this happen to me. Check it and wipe off the excess. The drip was coming from the bolt and no where else. Was the crush washer.
    2008 Evo X GSR. Custom tuned, Works panel filter, Intercooler pipe upgrade, TBE.
    Jan 2007
    Dirtee Jersee
    It's coming from the plug. Very slow, steady leak. I'll change the cw, see what happens.
