What does the tumble sensor do?
Results 1 to 4 of 4
This is a discussion on What does the tumble sensor do? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; What exactly does the tumble sensor do? What problems would/could it cause if it was defective?...
    Registered User verbal's Avatar
    Oct 2002
    Post What does the tumble sensor do?
    Oct 2004
    Westchester Cnty, NY
    Quote Originally Posted by verbal View Post
    Do you have a 2.5L? If so I am assuming you are referring to the TGV?
    Tumble Generator Valves above the fuel injectors remain closed during engine warm-up to create a tumble effect, which improves atomization of intake air entering the cylinders. This action creates a leaner air/fuel mixture to reduce emissions.
    check out the diagram
    http://www.drive.subaru.com/Win03_Manifold.htm
    2008 Satin White Pearl WRX Sedan w/ Navi
    2005 San Remo Red WRX Sedan w/ VF34 (traded)
    Pi Kappa Alpha | New England Flat 4
    Oct 2005
    Ocean Grove, NJ
    If it is stuck open, no problem. If it is stuck closed - it's choking your engine a little or a lot. I had mine go - and ended up doing the TGV delete. Mine was done by Precision Tuning, basically unscrew the flaps from the spindle, then take out the spindle and weld the spindle holes closed, then clean it up and put it back. I've had no issues since. I purchased the StreetTuner software to edit the map for my car with the Cobb AP. Turned off the checks for the TGV's.
    Oct 2002
    I have a 2002 WRX, so it's a 2.0. The dearship has just been calling it the Tumble Sensor.
    Any chance this could cause a tick sound?
