CODE P0340 all scooby gurus
Results 1 to 7 of 7
This is a discussion on CODE P0340 all scooby gurus within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; well, i was kinda owning on a eclipse gts in my 02 wrx and threw a CEL... checked at the ...
    Registered User InfernoAWD's Avatar
    Mar 2007
    well, i was kinda owning on a eclipse gts in my 02 wrx and threw a CEL... checked at the local auto zone and the code p0340 popped off... then the steering was hard as hell... no power steering=no fluid...checked it out and indeed there was no fluid, refilled it and looked underneath the fluid was literary pouring... ****ted brick for a bit, lifted up the car and found the source (a loose bolt that was probably left loose after the tranny was pulled) i tightened the bolt and problem solved, reseted the ECU and im golded....my question is would the leaking cause the the code P0340 to pop up?? is the pump somehow connected to such senser? please i need to know, the car idles perfect, no loss of power, no strange sounds... car is normal... can someone clarify that for me? please thanks in advance and sorry for the long thread
    flies like a butterfly, stings like when i pee
    Mar 2007
    can someone show me a picture or throughly explain where exactly the CaM POSITION SENSOR IS LOCATED... the one that throws the CEL P3040... please...that way i could check the sensor myself.... thanks
    Mar 2007
    BuMp.... FYI the car seems to be in great condition
    Mar 2007
    Europe
    Hi
    I would like to know too where is this sensor located? Please help, thanks.
    I got my P0340 when I revved over 6000rpm.. I reseted my ECU but I got this code again few days later revving over 6000rpm.
    Registered User spnkdrm's Avatar
    Southern CT
    Quote Originally Posted by scoobytune View Post
    Hi
    Uh, maybe don't rev that high again til it gets fixed.
    New EnglandF4
    Hawk-Eye Alliance #010
    Nov 2006
    Grand Island, NE
    Drivers side front, directly behind the timing belt cover and above/behind the upper cam sprocket.
    Mar 2007
    Europe
    Okay, I found it. I took it off and used some super cleaner to the connectors and put it back, no CEL so far. There is some kind of gasket around the sensor, should it be tight seal? I believe that I could put my finger through it from the side of the sensor. Flap gasket or something..
    Thanks.
