More engine woes
Results 1 to 4 of 4
This is a discussion on More engine woes within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I posted here a little while ago about a CEL. I went out and replaced my spark plugs earlier today, ...
    Registered User devik's Avatar
    Jun 2006
    PHX Metro
    More engine woes
    I posted here a little while ago about a CEL. I went out and replaced my spark plugs earlier today, which seemed to do the trick at first, until...
    On my test run around the block, everything seemed to be going okay. As I was making the last leg of the trip down the highway, I revved up a bit... as soon as the tach hit about 5,400, the engine seemed to misfire, badly. RPMs dropped about 200 or so for a moment then picked back up, hit the same spot and dropped again. After that, it was fine. Heard a faint 'pfft pfft' noise when this happened.
    Any ideas? It has done this once or twice before I installed the new plugs, I believed the old ones were simply bad. But I'm not getting a CEL when it happens, just the apparent missing. Unfortunately I'm not much of a mechanic, and I'm at a loss to explain it, now!
    That's not all, either. If I have the AC on, the engine seems to run very poorly. At idle, the vehicle trembles noticeably, but when the AC is disengaged it seems to idle fine. If I have AC on while moving, there's a slight tremble in the vehicle. I'm betting that my AC compressor is going bad. Has anyone else experienced this? Any way to troubleshoot this further? Any advice?
    Thanks for any help you guys can give.
    Registered User koogxone's Avatar
    Mar 2007
    The Best Coast
    Quote Originally Posted by devik View Post
    slight trembling is just one of the quirky things the wrx does - completely normal . another quirky little thing is that it idles higher with the AC on.
    -kyle
    bugeyemafia#126
    VF39'd, Bailey-tuned! 280.07whp 250.05wtq
    Jun 2006
    PHX Metro
    Quote Originally Posted by koogxone View Post
    I know that, but this is much more than normal. The idle is enough that the vehicle is rocking noticeably from side to side, and when driving, it feels like I'm driving across a grooved road. The vehicle is making a noticeable, physical and audible vibration, much more than it's ever done before.
    Registered User whiskeytech's Avatar
    Sep 2005
    Baghdad, Iraq
    did you ever figure out what it was? My buddy is having the same problem. We installed a set of perrin injectors and fuel rails and now he is having this problem too.
