Problem with taillights
Results 1 to 13 of 13
This is a discussion on Problem with taillights within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Having an issue with my wrx. Can't figure this out. MY02- Put my foot on the brake, brake lights come ...
    Jan 2007
    Minnetonka, MN
    MY02- Put my foot on the brake, brake lights come on. Turn on brights, high beams, or parking lights, the tail lights do not illuminate. Brake lights work regardless.
    Any suggestions?
    Jan 2007
    Minnetonka, MN
    I found a blown fuse under the steering wheel, behind the change compartment. It was the 10a second to the right all the way at the top. I replaced it with another 10a. I tested my tail lights, still not working. Checked the fuse, and it was blown again.
    Assuming it is a short, or bad ground, Where should I start looking? Behind the fuse box, tail lights, etc....
    Registered User Damien02WRX's Avatar
    Dec 2005
    California City, CA
    Check all associated taillight wiring with taillight harness for a short to ground.
    Registered User 68sprintb's Avatar
    Dec 2005
    San Jose, CA
    start where it's easy to get to: right by the tail lights. also look for other things that are on that same circuit. i have the FSM for MY05 which should be fairly close, and all that's on that fuse are: two front clearance lights, license plate lights, rear combination lights, and the trailer connector. another question, did the second fuse blow immediately or only after you turned on the brake lights?
    Blobeye Syndicate #75
    2005 OBP WRX Sport Wagon
    Stewart Warner Boost & Oil temp gauges / OEM 20 mm rear bar
    Cobb stg 2 / STi uppipe / Crucial Racing downpipe
    Stromung 2.5" catless centerpipe / ScoobySport New Age centre pipe & backbox
    Jan 2007
    Minnetonka, MN
    The brake lights work fine. I believe it blew when I turned on my brights, which should make my taillights, and license plate illuminate.
    I did recently install the cobb accessport...could I have tugged on something under there that would cause this, or is my best bet to look directly behind the tail lights?
    I appreciate your replies.
    Administrator
    May 2003
    Have you replaced any bulbs recently?
    Jan 2007
    Minnetonka, MN
    I replaced the headlight bulbs, and they work fine. None of the bulbs are out as far as I can tell. They just do not all work when they should. Everything works as normal, except Tail lights, and rear license light do not illuminate when brights/high's are on. When I unlock my car lights do not flash, but the interior lights turn on. When I flip the parking light toggle, nothing comes on.
    Jan 2007
    Minnetonka, MN
    Just bought some fuses. Tried replacing it one more time to make sure when it was blowing. Engine was not running, key was in the on position, fuse blew when brights were turned on.
    Administrator
    May 2003
    Quote Originally Posted by Chaotic Yeti View Post
    I would start looking at those bulbs you just installed. Either they are wrong (my guess) or defective.
    Moderator YBNormal07's Avatar
    Jul 2003
    PA
    Quote Originally Posted by Damien02WRX View Post
    This was the cause for my tailights not working on an 02 WRX and my 05 LGT legacy. I still have "firmly jiggle/bend" the wire leads directly into the plug for the lamp socket every now and then on my driver's rear. They come right back on then. But it had the same symptoms as yours...no rear light, but brake lights (and I think blinker) worked.
    tEh PriUs=teH faSTah!@@!
    306 AWHP/341 AWT, Stage 2
    Jan 2007
    Minnetonka, MN
    I appreciate all of your responses. I'll let you know what worked.
    Jan 2007
    Minnetonka, MN
    Exchanged headlights, replaced fuse, Bingo. No more problems. Trainrex-FTW.
    Thanks again
    Administrator
    May 2003
    Thanks again
    Anytime
