Spark plug question
Results 1 to 15 of 18
This is a discussion on Spark plug question within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Are there any spark plugs that can improve performance? By the way I have an 06 WRX. Any input would ...
    gil
    gil is offline
    Feb 2006
    Central Jersey
    Spark plug question
    Are there any spark plugs that can improve performance? By the way I have an 06 WRX. Any input would be appreciated,thanks.
    Registered User section9's Avatar
    Jun 2005
    AK49
    I don't know that it'll improve performance, but different ones have different service lives. I've got Iridiums. Lasts the longest of the bunch I believe. I'm sure there's several old threads on this subject. Try searching.
    Batmobile: 2002 WRX wagon RIP
    Registered User Botat1725's Avatar
    Oct 2005
    Easton PA
    Copper spark plugs are known to be the best performing, however you will need to change them very often, and spark plug changing is no easy task in a wrx. So iridiums are your best bet.
    ________________________________________________
    XPT Stage 2
    "Do you smell that? It smells like his clutch."
    "No, it's burnt rice."
    Registered User bcyb1029's Avatar
    Feb 2006
    Chicago
    Keep in mind that your stock plugs are NGK Iridiums.
    Tuned by Jorge at P&L, 240.83whp 239.60wtq at 14.8psi on 2.0L with stock td04 (But doesn't run)
    Jun 2005
    AK49
    Huh, no kidding? Mine came with platinums (02) and I tell you, that was so much a pain in the a** to replace them!
    Registered User koogxone's Avatar
    Mar 2007
    The Best Coast
    stock plugs are NGK iridiums? really? o_o
    well they should be fine for now then. if you start to mod and increase your performance onestepcolder iridiums aren't a bad idea.
    -kyle
    bugeyemafia#126
    VF39'd, Bailey-tuned! 280.07whp 250.05wtq
    gil
    gil is offline
    Feb 2006
    Central Jersey
    Quote Originally Posted by koogxone View Post
    gil
    gil is offline
    Feb 2006
    Central Jersey
    I've got 16k now , when should I change them?
    Nov 2005
    Central Florida
    Quote Originally Posted by gil View Post
    30k
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Mace Windu devilfluff's Avatar
    Feb 2005
    south jersey
    Quote Originally Posted by bcyb1029 View Post
    My stock plugs were NGK double platinums. I looked up the part # off the plug on NGK's website
    I replaced them w/ iridiums, though.
    BTW- maintenance interval for plugs is 60k on our vehicles(2002 at least)
    Dirty Jersey
    Part-Time Grammar Nazi
    RIP- '02 PSM Wagon
    SOLD- 08 Candy White MK5 GTI 6spd
    '15 WRB BRZ Limited, 6spd
    Moderator:Tri-State and Transmission & AWD forums
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    Are one step colder plugs necessary at stage 2?
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    Feb 2005
    south jersey
    Quote Originally Posted by 06wrx4me View Post
    They are not necessary at stage 2.
    I'm not sure at what point they become necessary, but I would install them w/ a turbo swap.
    Dirty Jersey
    RIP- '02 PSM Wagon
    Mar 2007
    The Best Coast
    the maintenance interval for our cars' spark plugs is really 60k? i've heard everywhere that it was 30k.. strange
    -kyle
    bugeyemafia#126
    Registered User Sooby-Doo's Avatar
    Dec 2005
    Tampa
    I posted this in another thread but I just want to make sure everyone knows so they don't get screwed because YES, changing those plugs is a *****!
    Just make sure when you get your plugs, if you get NGK Iridiums, DO NOT get the ones with a -11 at the end of the code. They are gapped to .44. You need them gapped around .28-.30. Can't gap Iridiums as they will either break or bend at an unsafe angle which compromises spark.
    The same code, just no -11. The 6's are stock and 7's are a step colder.
    I'm only mentioning this because all the Discount/Advanced Autoparts, and any other hardware/auto stores have the -11 code listed in their system and will inadvertently sell you the wrong ones.
    Get: BKR7EIX
    DO NOT GET: BKR7EIX-11
    I partially disagree with devilfluff, but only partially. I'm Stage 2 and have the one step colder NGK Iridiums. Are they necessary, no not really. Are they beneficial at Stage 2? That really depends on where you live and how you drive. (IMO)
    I'm in Tampa, FL and drive "spirited" on most occassions. Ambient heat combined with engine heat = lots of heat = beneficial. Now if your in North Dakota and drive your grandmother to her dr.s appointments, well I guess what the hell are you doing at Stage 2 j/k If you live in really cold weather you probably are not going to want them unless you change your plugs before winter as they can make for some rough starts in cold weather. All of that being said, one step is not an extreme difference and usually isn't an issue either way.
    S&R Built 2.5/2.0 '03 Hybrid w/ PE1818
    Scott Siegel Tuned 308whp/320wtq
    Vogtland Club Spec Springs on KYB AGX's
    ******* I BOOST, therefore I AM! *******
    Feb 2005
    south jersey
    As a general rule, copper spark plugs are changed every 30k(the 2.5RS's fall in this category), while platinum/double platinum(WRX)/Iridium are changed at between 60k and 100k intervals.
    I looked up the interval on Mitchell-On-Demand to confirm it.
    Remember, dealer recommended service intervals may not match manufacturer recommended service intervals.
    Changing the plugs early will not be harmful to the engine, so if it makes you feel more comfortable go for it.
    Dirty Jersey
    RIP- '02 PSM Wagon
