wrx losing power
Results 1 to 4 of 4
This is a discussion on wrx losing power within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Right my problem is that when I am in 5th gear travelling at 70 mph on the motorway the car ...
    Registered User ulsterscooby's Avatar
    Apr 2007
    Antrim Northern Ireland
    wrx losing power
    Right my problem is that when I am in 5th gear travelling at 70 mph on the motorway the car behaves like I have wrongly selected the gear ie gone into 5th when I meant to select say 2nd gear at about 20mph. The ride is sluggish and there is very little acceleration when I push the peddle has anybody any ideas what could be causing this ?
    I have also noticed that the boost takes much longer to build up in the lower gears although my Bov can be heard to operate on gear changes
    Thanks in advance
    Oct 2004
    Westchester Cnty, NY
    Quote Originally Posted by ulsterscooby View Post
    Thanks in advance
    First of all 5th gear should not have a lot of power as the engine is now spinning as fast as in say 3rd gear. If you downshift to 4th or 3rd on the highway you will get back all of the performance that you are missing.
    Boost should increase faster in lower gears.
    Why do you have a blow-off valve? That is probably causing issues as well.
    2015 Plasma Green Pearl XV Crosstrek Hybrid Touring
    2011 Lightning Red WRX LTD Sedan w/ Nav (returned)
    2008 Lightning Red WRX Prem. Hatch w/ Nav (returned)
    2005 San Remo Red WRX Prem. Sedan w/ VF34 (traded)
    Registered User tayhadar1's Avatar
    Apr 2006
    Spokane, WA
    Quote Originally Posted by D0WNxSH1FT View Post
    +1
    2004 WRX Sti Cobb Stage 2
    GO COUGS!!!
    Registered User 68sprintb's Avatar
    Dec 2005
    San Jose, CA
    5th is for cruising, not power, so that sounds perfectly normal
    Blobeye Syndicate #75
    2005 OBP WRX Sport Wagon
    Stewart Warner Boost & Oil temp gauges / OEM 20 mm rear bar
    Cobb stg 2 / STi uppipe / Crucial Racing downpipe
    Stromung 2.5" catless centerpipe / ScoobySport New Age centre pipe & backbox
