This is a discussion on Water pump tensioner bearing noise within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I have a 02 WRX, it is making bearing noise which is coming from the front of the engine. Does ...
I have a 02 WRX, it is making bearing noise which is coming from the front of the engine. Does anyone know what it might be? Also, is there a diagram showing the front end bearings on a WRX I can find somewhere on the web?
Thanks!
Thanks Drift! I will surely start off with that and hopefully that is the problem...
Do you remember how much the alternator belt tensioner cost you?
for the pully and both serpintine belts, i think it was around $30
member of teh sex... i mean bugeye mafia (#92)
Ok, I removed both the alternator belt, and the other belt – (a/c compressor?) and started the engine, the noise is still there and seems to be coming from the main engine crank which runs these belts. Does anyone know if there a bearing that goes there which could be the issue?
