Engine cutout - right-hand turn only - help.
Results 1 to 4 of 4
This is a discussion on Engine cutout - right-hand turn only - help. within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Wow, long time no post.. anyway. Lately, Ive been noticing more and more that if I take a sharp, or ...
    May 2003
    NY
    Lately, Ive been noticing more and more that if I take a sharp, or accelerated right hand turn, after I straighten out, the engine will cut out, almost feels like fuel was just shut off.. As long as I am moving, I dont stall, but the engine cuts out for about 2 seconds.. I can pretty much reproduce the problem on any right-hand turn.. However I've yet to do it on a left hand turn..
    Does that make ANY sense?? I dont have any mods other then a drop in K&N, havent done anything to the scoobie for years, and this randomly started to happen..
    Sometimes when I start it up, I hear a harmous hum from the rear of the car, maybe a fuel pump is on its way out?
    Any suggestions?
    2003 WRB WRX 5 spd
    wrxrus.com
    onewebway.com
    Registered User 68sprintb's Avatar
    Dec 2005
    San Jose, CA
    odd thing about WRXs, they have two fuel pumps sorta, a main pump for the fuel to the engine (on the right side of the tank) and a jet pump to get the fuel in the left side of the tank to the right side and into the fuel pump. if everything happens like you feel, then it seems the fuel is being pulled away from the main pump in the right side of the tank then has to be pulled into the right tank again by the jet pump. this could be from the baffling in the tank being broken, or the fuel pump not holding enough fuel pressure...
    Blobeye Syndicate #75
    2005 OBP WRX Sport Wagon
    Stewart Warner Boost & Oil temp gauges / OEM 20 mm rear bar
    Cobb stg 2 / STi uppipe / Crucial Racing downpipe
    Stromung 2.5" catless centerpipe / ScoobySport New Age centre pipe & backbox
    Registered User mittermiers's Avatar
    Jan 2007
    Latvia
    I had this problem when I hat Honda Accord
    when running on low fuel during right corners engine cutut for a second or so. Fuel starvation.
    May 2003
    NY
    Hmm, that sounds like it make sense.. Also sounds like my 7-year 75000 mile warranty should cover it!..
    Ill call the dealer and see what they say
    Thanks
    Dave
    2003 WRB WRX 5 spd
    wrxrus.com
    onewebway.com
