Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
This is a discussion on misfiring? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Originally Posted by koogxone i'm also getting new spark plugs and maybe coil packs. Just make sure when you get ...
    Registered User Sooby-Doo's Avatar
    Dec 2005
    Tampa
    Quote Originally Posted by koogxone View Post
    Just make sure when you get your plugs, if you get NGK Iridiums, DO NOT get the ones with a -11 at the end of the code. They are gapped to .44. You need them gapped around .28-.30. The same code, just no -11.
    Get: BKR7EIX
    Do not...repeat... DO NOT get the BKR7EIX-11. They are gapped to .44.
    I'm only mentioning this because all the Discount/Advanced Autoparts, and any other hardware/auto store has the wrong ones listed in their system and will inadvertantly sell you the wrong ones. With the issues your having you don't need to add more problems by having incorectly gapped plugs.
    Good luck and let us know how it goes.
    S&R Built 2.5/2.0 '03 Hybrid w/ PE1818
    Scott Siegel Tuned 308whp/320wtq
    Vogtland Club Spec Springs on KYB AGX's
    ******* I BOOST, therefore I AM! *******
  2. #17
    Jan 2007
    Moorpark, CA
    Nice! Yeah I like Yimi. I wish they were closer to me and I'd be there getting only their help to solve this. I'm in Simi Valley--Ventura County.
    Regarding the spark plug issue...that's what happened. They previous owner put the wrong ones in. The plug on 4 was all black and nasty. Fouled nice and good. I've got the correct .28 NGK in there now for all of 'em.
    What the heck could that whine be? Almost thinking I should make a vid and let some people on here listen to it. It's NO GOOD Well, that and the smoke...
    I have an FMIC, so I'm still working out the full recirc setup. This car also had a CAI on it. I would rather have the stock intake but I'm trying to make it work with what's on there to save some money.
  3. #18
    NY
    you need to learn little more about your car there kiddo !
  4. #19
    Jan 2007
    Moorpark, CA
    Thanks so much subz. Extermely helpful. Do you have any "useful" input?
  5. #20
    Registered User koogxone's Avatar
    Mar 2007
    The Best Coast
    as for me, the previous owner had modded the injectors and might have failed to get them matched by an injector servicing company, as he should have with modded stock injectors. yimi sent mine to rc injectors and they should be back any day now, flowtested and matched
    hopefully that was what was making my car run inconsistent air-fuel ratios. if that was the problem, they can opensource tune it on friday and i can pick it up then. but if rc injectors sends them back and says that the injectors are fine and perfectly matched, we won't know what's wrong with it at all =/
    i think nazisock is a better place for you, subz.
    -kyle
    bugeyemafia#126
    VF39'd, Bailey-tuned! 280.07whp 250.05wtq
  6. #21
    Registered User gda03subaru's Avatar
    Mar 2007
    Austin, Texas
    agreed go back to nasioc with the rest of the idiots with nothing better to do!
    HAVE YOU SEEN ME?
