Lean System Conditions
Results 1 to 14 of 14
This is a discussion on Lean System Conditions within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; well, first of all, hi to everyone! , i just purchased a 02' wrx lightly modded, which includeds a SSQV ...
    Registered User InfernoAWD's Avatar
    Mar 2007
    well, first of all, hi to everyone! , i just purchased a 02' wrx lightly modded, which includeds a SSQV BOV, Racing clutch, and an aftermarket cone filter connected to the stock intake, and a turbo timer... i have been happy with her until a couple of days ago when it threw a CEL, decided to chekc my fuel cap and reset the system... good for about two days, and then it threw a CEL again....checked it out at an auto zone, and code P0171 (lean system bank 1) came up... therefore I am running lean... I've done research and concluded that the reasons are the following:
    Vacuum Leak...not Boost leak
    O2 sensor
    Fuel Pressure
    Exhaust leak
    I am just wondering what else could it be... , i will be checking the fuel pressure and checking for loose/disconnected hoses.... any help will be extremely appreciated, please, BTW, the second time the light came on i just reseted the ECU and it was good for about a 100miles, then i did it again thinking it was a glitch and it was good for 40 miles.... could it be that im just running lean "sometimes"? or is it the type of fuel? because i made the mistake of putting 87 octane in it thinking it was 91 octane, there is not hesitation, bogging, loss in performance or overheating...please any input would help
    Administrator
    May 2003
    My money is on the ghetto intake causing it.
    May 2005
    Phillytown, PA
    Quote Originally Posted by Trainrex View Post
    +1
    Your mod list is not so good.
    Mar 2007
    so...imma try to go back to stock air box, and check the pressure...anything else? tuninG?
    Registered User tayhadar1's Avatar
    Apr 2006
    Spokane, WA
    take the bov as well and put the stock one on
    2004 WRX Sti Cobb Stage 2
    GO COUGS!!!
    Mar 2007
    Well, just wondering...how much would a stock airbox and a stock BOV would cost??? a range?
    Mar 2007
    Well, just wondering...how much would a stock airbox and a stock BOV would cost??? a range in prices?
    May 2005
    Phillytown, PA
    You could get an SPT Intake from TheKingofParts if you would like an intake. That one at least works.
    The BOV while not the best shouldn't cause horrible problems.
    Registered User 68sprintb's Avatar
    Dec 2005
    San Jose, CA
    you can eliminate the O2, odd MAF readings (cuz of the cone filter), and fuel pressure with an OBDII diagnostic scanner, just look at the O2 sig, fuel trim (which is what caused the P0171 in the first place), and the MAF sig for any odd readings...
    Blobeye Syndicate #75
    2005 OBP WRX Sport Wagon
    Stewart Warner Boost & Oil temp gauges / OEM 20 mm rear bar
    Cobb stg 2 / STi uppipe / Crucial Racing downpipe
    Stromung 2.5" catless centerpipe / ScoobySport New Age centre pipe & backbox
    Mar 2007
    well, i will re-fuel today with high octane gas and reset the ECU and let you guys know the developments....thanks for the input....although more ideas/suggestions will be deeply apprecciated...
    Mar 2007
    well, what do you know...the car is better now... i will keep watching for any weird stuff... thanks for all the inputs and hits, you guys deserve a bigger turbo!
    Mar 2007
    I take back what i said on the last post! I was crusin' on the FW and the CEL goes on again...so it was not the type of gas i was using. it threw the same CEL with 91 octane, but the weird thing is that its only after a certain amount of miles, which ranges from 60-200mi until in throws the CEL again... next i will try going back to the stock airbox
    flies like a butterfly, stings like when i pee
    Mar 2007
    well fellas, new developments, ran another diagnostic and this time it said that the fuel system for bank 1 was too lean (bank 1 identifies the location for cylinder #1...meaning the spark plugs, while bank to identifies the cylinders for the opposite bank)...however, i only got bank 1...has anyone has had this trouble? with the spark plugs i mean?
    Dec 2005
    San Jose, CA
    don't get confused by the Bank 1 / Bank 2 stuff, that's just there in case there are two O2 sensors because there are two exhaust banks, ie a V engine... subaru has one O2 sensor after the headers meet and form one pipe, so Bank 1 is for all 4 cylinders... ignore the plugs in this instance, they wouldn't cause the fuel trim to go high enough to cause a P0171... since you say you can't find any vac leaks, did you check fuel pressure?
