BRAKE light on and off while driving
Results 1 to 10 of 10
This is a discussion on BRAKE light on and off while driving within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Anyone else seen this? Could it be yet another cold-weather trick for the 02 WRX's? When I would disengage the ...
    Registered User grizzle's Avatar
    Feb 2006
    Indiana
    Anyone else seen this? Could it be yet another cold-weather trick for the 02 WRX's? When I would disengage the e-brake, the BRAKE light on the inst. panel would stay on. Lately, it will come on when I accelerate hard. But, the traction is good and tires are new, is this some sort of traction warning, does anyone know? The BRAKE staying on after disengaging the e-brake seemed to go away with the cold weather, but i still get the BRAKE indicator at times when driving. usually pops up during hard accel in 2nd or 3rd gear.
    Congressional Lobbyist for the Bugeye Mafia
    As your brake pads wear down, the fluid level in the reservoir drops. This causes the floater to trip the circuit and the light comes on. Check your brake fluid level, and if it's been some time or you've put on hard use, check your brakes (you should be checking the brakes anyway every time you rotate wheels since the wheels are off to begin with).
    Hammerdown Mod of Thunder josnroh's Avatar
    Feb 2003
    oHIo
    Had the same problem,it was low on brake fluid.
    JOE/Flyin' Under the Radar
    2015 Buckeye Boxer WRX
    2003 Hammerdown Wagon WRX(sold)
    1983 GL-10 Wagon (RIP)
    Sometimes you get the best light from a burning bridge.
    http://badges.fuelly.com/images/sig-us/282947.png
    Feb 2006
    Indiana
    thanks. can I simply add brake fluid? i try to be a DIYer, but i must admit i am noob on the brakes.
    Registered User 68sprintb's Avatar
    Dec 2005
    San Jose, CA
    yep, it's real easy... open the hood and check that it's actually low, then just add some DOT3 (i think) brake fluid to the brake fluid master reservoir
    Blobeye Syndicate #75
    2005 OBP WRX Sport Wagon
    Stewart Warner Boost & Oil temp gauges / OEM 20 mm rear bar
    Cobb stg 2 / STi uppipe / Crucial Racing downpipe
    Stromung 2.5" catless centerpipe / ScoobySport New Age centre pipe & backbox
    Jan 2005
    Canada B.C.
    Yes DOT 3 or DOT 4.
    '02 WRX 4EAT, 311,000KMs/194,500Miles, Sold. Best car I ever had. '09 STi stage 1, hope this one will be good too...
    Quote Originally Posted by grizzle View Post
    Yes. The manual (and usually the reservoir cover) specify the type to be used. Do keep in mind though that your pads are not as thick as they used to be, and it's a great idea to figure out exactly what's left. Many shops provide free brake inspections if you're not up to it, or look here and/or scoobymods for instructions.
    Since the light only comes on when you're accel/decelerating it's unlikely there's a leak. A solid light and silly feel to the pedal would be cause for alarm though. Every time you rotate wheels it's a terrific idea to check the brakes (pad thickness and make sure no juice is coming out the lines or calipers).
    It may also just need a computer reset. I was having this same problem in my Honda, and I happened to need an oil change / tire rotation and when they did it the brakes were looked at and still had like 70% of their pads left. The fluid was checked and it was fine too. Took it to a honda specialist and the guy checked brakes / fluid and since there was nothing wrong he didn't charge me and just told me how to reset the computer.. This was about 9k miles ago and I haven't had any problems.
    Feb 2006
    Indiana
    THANKS! added a little DOT3 and the light went away. it is hard to tell the level on the reservoir, though. I skimped a little out of caution. I will need the wheels rotated soon, so i will do the brake check. as for now, pedal feels normal and no squeaks from the stoppers.
    OK great. Another thing to check while the wheels are off are the shafts; make sure they are dry. Of course make sure the brake lines are dry too. Then, when the wheel is back on, check for bearing wear by grasping the wheel at the top and bottom edges and pulling -- there should be no play.
    Be careful though, and make sure the car is supported correctly, especially if you're going to get close to it to check the pad thickness.
