Results 1 to 5 of 5
This is a discussion on Intercooler Reinstall Problem within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I took off my intercooler last night to install my new spt turbo heat shield. When I went to put ...
    Dec 2006
    I took off my intercooler last night to install my new spt turbo heat shield. When I went to put my intercooler back on I could not get the intercooler pipes to go back on (turbo and throttle pipe)... any suggestions on how to make the install work... am I doing something wrong?
    Jan 2005
    Canada B.C.
    I start the turbo hose first by about 1/4" then the throttle body hose, then lots of wigling and some swearing/sweating and finaly it will go on.
    '02 WRX 4EAT, 311,000KMs/194,500Miles, Sold. Best car I ever had. '09 STi stage 1, hope this one will be good too...
    Oct 2002
    The Old Folks Home
    I use "the string trick".
    I put a little bit of Vaseline on the inside of the hose that attaches to the turbocharger, to help it slide on. Then I get the throttle hose started, not worrying about the hose yet.
    After that's started:
    Look on the hose that attaches to the turbocharger. Close to where it goes on the turbo, look for a little plastic hanger off the side, that appears to do nothing. I hook a piece of string/wire onto it, and use that to pull in the direction of the turbo. Usually I have to give it 2-3 tries, and it'll pop right on.
    --Ray
    Proud owner of a N.E.R.D.
    Nov 2005
    Central Florida
    wow good info ray
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Registered User bcyb1029's Avatar
    Feb 2006
    Chicago
    I used to heat up the y-pipe to slide it on the turbo.
    Tuned by Jorge at P&L, 240.83whp 239.60wtq at 14.8psi on 2.0L with stock td04 (But doesn't run)
