Results 1 to 2 of 2
This is a discussion on Burning acc belts within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Just a quick survey. If I have my heater fan on while I floor it in first I get a ...
    May 2006
    Burning acc belts
    If I have my heater fan on while I floor it in first I get a burnt rubber smell which I have narrowed down to the accessory belts. I have replaced both and the tension is fine. They are the OEM belts they just won't grip under hard acceleration. anyone else have this problem
    Registered User ktmrider's Avatar
    Sep 2006
    Albuquerque, NM
    Heater or defrost? Defrost engages your A/C compressor to keep the system from drying out during winther months. If the A/C is indeed coming on then you may have a problem with the compressor or line freeze. High pressure will stop the compressor from turning but still engage the clutch so the engine is trying to turn everything. The belt loses in this case!
    Easy to check, pop the hood and turn on the heater. If the A/C clutch engages that is most likely your problem.
    2005 Legacy GT - stock for now
    1991 Galant VR4 - Sold
    2002 WRX Wagon - Sold
