Results 1 to 15 of 15
This is a discussion on Oil change . . . doh!! I forgot something important within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So today I changed my oil - (mobil 1 ftw) and as I finished I found something that bothered me ...
    Registered User dowright82's Avatar
    Feb 2006
    Tennessee
    So today I changed my oil - (mobil 1 ftw) and as I finished I found something that bothered me sitting at the bottom of my old oil pan . . .
    the damn washer that was supposed to go on my oil drain plug.
    Grrrrr . . . . -
    So I can either A) try to be as fast as possible at unscrewing, then rescrewing and add more $$$ Mobil one accordingly, or
    B) Leave it screwed in like it is, keep the washer and not worry about it till next oil change.
    How critical is that little guy?? HELP! What should i do?? can I get away with it for this one change??
    thanks in advance.
    SOLD: 2004 WR Blue WRX
    SOLD:2006 WR Blue Wrx - Perrin 25mm Front Sway + 22mm Rear Adjustable Sway and Kartboy Endlinks - Nitto Invo 225/45/17 - Opensource STG One.
    CURRENT: 2006 Legacy GT Limited - STOCK (for now)
    Registered User EmsTraumajunke's Avatar
    South Mississippi
    I think id put the washer on there, Its there for a reason. you should loose much oil maybe a qt if your fast enough and loosing a qt of oil is better then some how the plug leaking a few miles down the road and looseing all the oil.
    Moderator Integra96's Avatar
    Apr 2002
    Utah
    I'd watch your car for a little while. It seems possible that you could get away with a minimal/no leak without the washer. Give it a shot - if it leaks, do it over.
    "Did you sleep well?"
    "No, I made a couple of mistakes."
    -- Steven Wright
    Feb 2006
    Tennessee
    bump for more opinions
    Registered User wRxOne's Avatar
    May 2002
    Vallejo, CA
    That washer is actually a gasket to prevent the oil from seeping out of the filter. However I have forgetten to install that without major problems. It's always a good idea to always make sure that is installed.
    Chuck Norris' tears cure cancer. Too bad he has never cried.
    Registered User powder's Avatar
    Aug 2006
    WA State
    I got away w/ it but will be puting it back on for the next oil change. I've had it off for 3200 miles or so.
    Blobeye Syndicate #2004
    Military Militia #30-06
    2004 WRX - JBP:Stage 2:13.93 @ 96
    Wingless alas. Too bad it took a 50 ton truck to make it happen.
    ODJ
    ODJ is offline
    Registered User ODJ's Avatar
    Jan 2006
    Tampa, FL
    I've READ that the oil drain plug washer's primary purpose is to keep us from stripping the threads in the oil pan when replacing the plug.
    I would think the plug would seal well enough on it's own for a while. If you didn't over-torque the plug, I would say you'll be OK until your next oil change (just keep a sharp eye out for any signs of leakage).
    I think the tranny drain plug uses the same crush washer. When I get an OEM oil filter from the dealership, the parts guy includes a new crush washer, but he won't give me any extras. Does anyone know how to obtain these washers in bulk? It would be nice to have some lying around.
    UNSPOILT BY PROGRESS
    Oct 2005
    Late Devonian
    Quote Originally Posted by ODJ View Post
    For the record, the tranny drain plug uses the same crush washer. When I get an OEM oil filter from the dealership, the parts guy includes a new crush washer, but he won't give me any extras. Does anyone know how to obtain these washers in bulk? It would be nice to have some lying around.
    Thats ridiculous - my dealership will sell me a handful and I just keep them in my change drawer.
    Jan 2005
    Canada B.C.
    If it don't leak don't worry about it...
    '02 WRX 4EAT, 311,000KMs/194,500Miles, Sold. Best car I ever had. '09 STi stage 1, hope this one will be good too...
    Yes.
    No, the gearbox uses a copper washer that's a different size and not a crush design. The parts numbers are different too.
    Buy as many as you want from any dealer.
    Nov 2005
    Central Florida
    + 1 me too
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Boba Fett BrianH's Avatar
    Oct 2003
    Kicking Babies
    Naapa, any auto store. If that fails find a subaru vendor online I'm sure they'll sell them to you in bulk. Your parts guy is a ****hole.
    ODJ
    ODJ is offline
    Jan 2006
    Tampa, FL
    Hmm, the dealership parts guy told me they were the same washer. It's been a while since I changed my tranny fluid, but I thought that the two washers looked the same when I had them side by side. Damn, now I'm worried that I've got the wrong washer for my tranny drain plug.
    Quote Originally Posted by BrianH View Post
    And Robert's your father's brother. The simplest answer is usually the best.
    On my bugeye 5MT they are different washers with different part numbers, different design, different costs, and different materials. Are we talking about the same washer? Are you comparing the crush washer for the oil filter with the washer that goes on the gearbox drain plug? If your fluid is still in the gearbox (as opposed to on the ground, say) I'd not worry too much about what's already been done.
    Hammerdown Mod of Thunder josnroh's Avatar
    Feb 2003
    oHIo
