To maintain your warranty...3-3,500 miles and replace the OEM filter with an OEM one.
This is a discussion on hey. how often should i change my oil if i use mobile 1 5w30 within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hey how often should i change my oil if i use the mobile one 5w30 syntatic please let me know ...
hey how often should i change my oil if i use the mobile one 5w30 syntatic please let me know thanks.
Without getting an oil analysis, there's no for sure way to know. I think a 5,000 mile OCI is just fine with Mobil 1, as long as you aren't beating the crap out of the car with track days all the time, etc.
"Did you sleep well?"
"No, I made a couple of mistakes."
-- Steven Wright
well i use mobile 1 10w30...more backfire ha, other than that though depending on how hard you run your car and if your running a huge downpipe and exhaust check it every 2-3 weeks or so.
i change mine every 2k but i have nothing better to do
All We'll Drive
DIFFERENT STROKES
POST WH0RE KING
I run mobil 1 10w30, and i change it every 6k miles. But i change the filter ever 3k. Oil always comes out as clean as it should.
NEW!! 09 WRX 5-door Black Base
Old - 2006 Geep GC Hemi
Older - 06 M3 Vert
Oldest - 04 WRX WRB - cobb stage 2, borla 3" exhaust, erz dp
just check it everytime you fill up that will let you know if it is getting low or if you need to change it.
I talked to a 17 year subaru tech and he said you can do the 7500 mile oil/filter change as stated in the owners manual if you use a good oil like valvoline synpower 5w40 (not the 5 or 10w30) or any ACEA spec A3 oil. He stated most mobil1 oils are not rated ACEA A3 so it wont go to 7500 miles as safe. I thought valvoline seemed an odd recommendation until I found out that the 5w40 version is popular with VW freaks some of which go 10k on it with long engine life to boot.
He is correct based on the data I got from my motor and data I've seen posted elsewhere. There are several M1 variants that are ACEA A3. Other specs to look for if you can't find an ACEA are MB229.5 (or 3 in a pinch), BMW Long Life 0x, and/or VW 505x.
Commonly available M1 ACEA A3 variants include 0W-40 and 15W-50. The 5W and 10W 30s used to be derived from the same base and were A1 (not bad but not A3 quality; I'd still use them anyway, they're fine).
I use M1 0W-40 and, although it's not as robust as their now extinct 5W-40 Truck/SUV, it is quite good. It will thin out initially and then thicken as time goes on and it remains generally within spec (a true 40).
Also keep an eye out for Mobil Delvac1 5W-40, a high-boost, high-temp, high-load oil with an SL rating that is intended for serious fleet users. This is what they used to sell as 5W-40 Truck/SUV and works great in our motors (it's overkill frankly).
As to visual inspection, if you think of it, clear oil after several K miles of use is worrisome. The colour changes as the oil changes chemical composition (it's additives are depleted and it solubilizes junk out of the motor like it should). In two of my cars I'm using M1 for at least 5000 miles a pop; one is the EJ205 with M1 0W-40 and the other is a Honda V6 3.5L with 5W-20. Both start out honey coloured and get darker. Both are changed well before they are "done" at 5,000 or so and both are dark brown/black at that point. No way to tell by colour; you need oil analysis data to tell.
<-- Just received my shipment of Amsoil 5W-40 for teh summer. Eager to see how it does...I've read very good things about it.
http://www.amsoil.com/StoreFront/afl.aspx
I'm giving my current M1 5W-30 a few more weeks of service and then changing it out before we get our lovely 124 degree summer temps.
-- Steven Wright
I've not tried their products (philosophical differences) but:
1. I hear good things about your particular choice.
2. They've been very professional in their responses to several questions I emailed them in the past.
I think their 5W-40 is intended for MB229.5 and VW505 applications (although it's probably not spec'ed formally), so it should be quite robust and very competent. I expect you'll be quite pleased actually.
Can you point me to the guy at Mobil that decided to kill off their 5W-40 Truck/SUV (the cheap, easy to find, rebadged Delvac1)? I'd like to beat him senseless and I'll put in a few kicks on your behalf too if you prefer.
BTW regaring your weather, if you have metal railings that are flat, you actually can fry an egg on them (it won't work on a sidewalk like the story goes, but a metal railing ought to).
