timing belt... help
Results 1 to 7 of 7
This is a discussion on timing belt... help within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i think my timing belt is going but im not sure. i have 82k on my wrx and its the ...
    Registered User bboynems's Avatar
    Nov 2006
    union
    timing belt... help
    i think my timing belt is going but im not sure. i have 82k on my wrx and its the stock belt on there. it starting to make like a squeeking noise. any sugestions on what it may be ??
    Registered User ArthurDent's Avatar
    Aug 2006
    South Florida
    Timing belts won't squeal when they wear out, they break. A timing belt is "cogged" (which means it has teeth that will mesh w/ the timing gears) and won't slip in such a way that could be audible.
    What you're probably hearing is an accessory belt (driving the alternator, power steering or whatever) slipping that will most likely need to be replaced.
    Aug 2003
    Richmond, KY
    +1
    That aint your timing belt...they break, not slip and it it was off by a tooth or two, you would definitly know it for a few minutes until the internals of the engine came to a crashing halt...happend on my 95 Talon TSi, thanks to a Firestone mechanic.
    It's an accessory belt...my wife's car does that when it is cold outside
    Moderator
    Jul 2003
    Maryland
    It is probaly your Acc. belt like several others have stated. I will tell you with that many miles on the stock belt I'd suggest some routine maintance.
    Water pump, oil pump, timing belt, acc belt, and a good check up on everything else the next time you go to a trusted shop.
    Registered User powder's Avatar
    Aug 2006
    WA State
    Are suby engines non interferance?
    Blobeye Syndicate #2004
    Military Militia #30-06
    2004 WRX - JBP:Stage 2:13.93 @ 96
    Wingless alas. Too bad it took a 50 ton truck to make it happen.
    Registered User REXYSTi's Avatar
    Apr 2006
    Seattle
    Subaru are interferance valves..... Be careful when it comes to timing belts... have it replaced when it calls for it... Bent valves=no good......
    Posted already- timing belts dont squeal they just break- any squealing will come from a acessories belt- if its just in the morning and its cold its normal most the time- check for leaky water pump if it squeals all the time even after warmed up... also your at that time for belt job never to early to have it done....
    ScoobyDMCtt
    Aug 2006
    WA State
    Quote Originally Posted by REXYSTi View Post
    Good to know.
