Oil change delusions!
Results 1 to 9 of 9
This is a discussion on Oil change delusions! within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; So I bought a 2002 WRX. I have no idea when the last time the oil was changed and I ...
    Feb 2007
    So I bought a 2002 WRX. I have no idea when the last time the oil was changed and I had driven the car for a week. Car seems fine, I checked the level and it was perfect and also happened to be a middle dark color.
    Well anyhow, I changed the oil today to Mobil 1 0W40.
    First off, changing the oil on these cars has to be the EASIEST I have ever seen. Everything is right in front of you, no need to reach for anything but let's get past this.
    I began to notice that before I changed the oil that the car had a slightly loping idle. I know the car is stock and no one messed with the cam so the loping disturbed me. Figured maybe the timing was off.
    Anyhow, I changed the oil and now the car seems to run smoother, the engine seems quieter and the odd lope seems gone.
    Are these cars really that sensitive to oil or am I entirely delusional?
    I've ordered a drop in K&N filter, PIAA bulbs, accessory belts (just to have new ones), a fuel filter and NGK Iridium plugs. I wonder if the car will react so nicely to these general items =)
    Anyhow, anyone notice such a drastic change from a simple oil change?
    Registered User ryanwrxduksa's Avatar
    Jun 2006
    NW ct
    if it had cheap old oil before, running something better would deffinetly make an improvement. i run royal purple, because its proven to improve gas mileage and hp, not sure about hp but gas mileage and motor noise is a lot quieter.
    07 white STi in CT
    Aug 2003
    Richmond, KY
    Add a Fumoto valve and you can change the oil faster than a NASCAR pit crew can change a tire!
    Moderator Integra96's Avatar
    Apr 2002
    Utah
    Probably delusional, but I swore I could feel/hear the difference after an oil change in my old Integra. However, I don't claim to be able to detect the difference with my WRX.
    "Did you sleep well?"
    "No, I made a couple of mistakes."
    -- Steven Wright
    Registered User powder's Avatar
    Aug 2006
    WA State
    Quote Originally Posted by ryanwrxduksa View Post
    +1 for RP
    Blobeye Syndicate #2004
    Military Militia #30-06
    2004 WRX - JBP:Stage 2:13.93 @ 96
    Wingless alas. Too bad it took a 50 ton truck to make it happen.
    Registered User blahblah's Avatar
    Sep 2003
    Chi-cago
    my car has a similar lope to it occasionally. I'm using redline syth right now. wonder if its the oil
    282 AWHP...267 lb-ft torque.
    2005 WRB WRX Sedan
    "he's a domestic fan with a hunger for rice"
    Apr 2002
    Utah
    The lope, wiggle, shake, or whatever you want to call it is completely normal for Subies and changing oil will not get rid of it.
    -- Steven Wright
    Aug 2006
    WA State
    by lope, what is meant? When i start my car after it's warm it bogs to about 400 rpms or so then goes up to idle. That what you're talkin bout?
    Sep 2003
    Chi-cago
    mines not that bad. It just wavers a lil and vac goes up and down 2 psi or so. If i didnt have an exhaust it probably wouldnt even be noticeable
    2005 WRB WRX Sedan
