http://www.subaru.com/owners/schedul...=SCHEDULE_2002
They call for inspection on the trans fluid and replace most others - brake fluid, coolant, oil. Be careful about what coolant you use, there have been some problems. I don't know anything about the automatics, but expect that the right DOT etc. should be fine. You can consider a better performing brake fluid, but it will probably have to be replaced more often. The rear differential isn't too finicky, just get the right grade and decide if you want synth or not. This is an automatic right?
Check out the maintenance sticky for the instructions if you want to DIY
LinkBack URL
About LinkBacks
