STi 2004-07 Part Numbers
Results 1 to 8 of 8
This is a discussion on STi 2004-07 Part Numbers within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; A/C : 73421FE001 Impreza STI 2004-2006 Air Conditioning Components HOSE DISCHARGE ASSEMBLY WITH ORING FOR 2004-2006 IMPREZA STI ALL (item ...
    Moderating YOU
    before you had your Subaru!
    Verdugo's Avatar
    Jan 2002
    Sea-Town, WA
    A/C :
    2004-2006 Air Conditioning Components HOSE DISCHARGE ASSEMBLY WITH ORING FOR 2004-2006 IMPREZA STI ALL (item 10) (this is the discharge hose from the top left of the condensor to the compressor)
    73422FE031 Impreza STI
    2004-2005 Air Conditioning Components SUCTION HOSE & ORING (ASPIRATOR) FOR 2004-2005 IMPREZA STI 2.57 ALL (item 11) this hose & pipe combo runs from the top of the compressor back to the heater core at firewall)
    73431FE060 Impreza STI
    2004-2006 Air Conditioning Components PIPE LIQUID & ORINGS FOR 2004-2006 IMPREZA STI ALL (item 8) (this is the pipe from the top left of the condensor back along the left and meets the evaporator pipe)
    73431FE040 Impreza STI
    2004-2006 Air Conditioning Components PIPE TO EVAPORATOR FOR 2004-2006 IMPREZA STI 2.57 ONLY (item 9) runs along firewall from front liquid pipe to firewall & connects to evaporator
    73412FE000 Impreza STI
    2004-2006 Air Conditioning AC Dryer LIQUID TANK COMPLETE FOR 2004-2006 IMPREZA STI 2.57 ALL (item 4) (this is the receiver dryer unit) (NOTE this part is attached to the condensor and if you order the condensor it will included already)
    73111FE040 Impreza STI
    2004-2006 Air Conditioning Compressor COMPRESSOR UNIT OEM FOR AIR COND FOR 2004-2006 IMPREZA STI ALL (item 8) (complete with clutch)
    Air Filtration :
    G3210FE100 Impreza STI
    2004-2006 Air Filtration AIR FILTRATION/ POLEN FILTER for Cabin 2004-2006 IMPREZA STI
    Armrest Extension :
    J2010FE030 Impreza STI
    2005-2007 Armrest Extension ARMREST EXTENSION ALL 2005-2007 IMPREZA STI
    J2010FE022 Impreza STI
    2004 Armrest Extension ARMREST EXTENSION FOR IMPREZA STI 2004
    Auto Dim Mirror :
    H501SSA000 Impreza STI
    2004-2005 Auto Dim Mirror AUTO DIMMING MIRROR WITH COMPASS FOR IMPREZA STI
    Auto Dim Mirror, With HomeLink :
    H501SAG100 & H501SSA040 Impreza STI
    2004-2007 Auto Dim Mirror, With HomeLink AUTODIM MIRROR COMPASS KIT WITH HOMELINK FOR 2004-2007 IMPREZA STI (with adaptor) (Each HomeLink button can be programmed to activate one of your homes radio frequency controlled systems, such as garage doors and security gates almost any system)
    Axle :
    28044AA000 Impreza STI
    2004-2007 Axle AXLE NUT FRONT or REAR
    28023PA050 KIT Impreza STI
    2004-2006 Axle Boots, Inner BOOT KIT FOR FRONT AXLE, INNER (DOJ) FOR 2004-2006 IMPREZA STI left or right (includes boot, grease. clamps & axle nut) (items A, E and 1 each of bands C & D)
    28397FE000 KIT Impreza STI
    2004 Axle Boots, Inner BOOT KIT FOR REAR AXLE, INNER (DOJ) FOR 2004 IMPREZA STI ONLY left or right (includes boot, grease. clamps & axle nut) (items A, E and 1 each of bands C & D)
    28497FE020 KIT Impreza STI
    2005-2006 Axle Boots, Inner BOOT KIT FOR REAR AXLE, INNER (DOJ) FOR 2005-2006 IMPREZA STI ONLY left or right (includes boot, grease. clamps & axle nut) (items A, E and 1 each of bands C & D)
    28323FE010 & 28395AG030 & CLAMPS Impreza STI
    2004-2006 Axle Boots, Outer BOOT KIT FOR FRONT AXLE, FOR AXLE, OUTER ONLY FOR 2004-2006 IMPREZA STI ONLY (includes boot, grease & clamps)(items B, E, and one each of C & D)
    28496FE000 KIT Impreza STI
    2004 Axle Boots, Outer BOOT KIT FOR REAR AXLE, OUTER CV ONLY FOR 2004 IMPREZA STI ONLY (includes boot, grease & clamps)(items B, E, and one each of C & D)
    28496FE020 KIT Impreza STI
    2005-2006 Axle Boots, Outer BOOT KIT FOR REAR AXLE, OUTER CV ONLY FOR 2005-2006 IMPREZA STI ONLY (includes boot, grease & clamps)(items B, E, and one each of C & D)
    Battery, Parts Related :
    81601FE030 Impreza STI
    2004-2005 Battery, Parts Related BATTERY CABLE ASSEMBLY FOR 2004-2005 IMPREZA STI 2.57 ALL (item 2)
    81608GA110 Impreza STI
    2004-2006 Battery, Parts Related POSITIVE BATTERY TERMINAL FOR ALL IMPREZA STI (item 4)
    SOA3881000 Impreza STI
    2004-2007 Battery, Parts Related SPT BATTERY HOLD DOWN UPGRADE FOR 2004-2007 STI ALL
    J6010FS000 Impreza STI
    2004-2007 Battery, Warmer Add on BATTERY WARMER KIT FOR 2004-2007 IMPREZA STI
    Bearings, Wheel :
    28316FE000 28015AA070 28015AA080 Impreza STI
    2004-2006 Bearings, Wheel FRONT WHEEL BEARING & 2 SEALS FOR 2004-2006 IMPREZA STI (Items 9, 10 & 11) (for housings and hubs see section under suspension)
    28016PA010 & 28015AA070 & 28015AA080X2 Impreza STI
    2004-2006 Bearings, Wheel REAR WHEEL BEARING & 3 SEALS FOR 2004-2006 IMPREZA STI (items 14, 16 & 18)
    Armin - ClubWRX Admin/Moderator since 2002
    Vice President and Editorial Manager, NWMotiv.com
    Photography Portfolios: ArminAusejo.com | ArminWeddings.com
    President, Project One Car Club
    02 WRX "EVA-00" | 15 Audi S3 "Ella" | 2010 A4 (traded in) | 02 M3 "M-Thrizzle" (traded in) | 08 STI "Blaze" (sold)
    djrez4 is a genius | ScoobyDMC #010
    Moderating YOU
    Verdugo's Avatar
    Jan 2002
    Sea-Town, WA
    Body :
    93063FE030 Impreza STI
    2004-2006 Body, Emblems STI FENDER DECAL FOR 2004-2006 IMPREZA STI
    93073FE580 Impreza STI
    2004-2006 Body, Emblems STI EMBLEM pink & chrome
    93073FE710 Impreza STI
    2004-2006 Body, Emblems STI EMBLEM pink & black
    59110FE062 & CLIPS 59122FA010X4 Impreza STI
    2004-2005 Body, Fender Liners FENDER LINER RIGHT FRONT FOR 2004-2005 IMPREZA STI SEDAN ALL (comes with clips)
    59110FE141 & CLIPS 59122FA010X4 Impreza STI
    2006 Body, Fender Liners FENDER LINER RIGHT FRONT FOR 2006 IMPREZA STI SEDAN ALL (comes with clips)
    59110FE071 & CLIPS 59122FA010X4 Impreza STI
    2004-2005 Body, Fender Liners FENDER LINER LEFT FRONT FOR 2004-2005 IMPREZA STI SEDANS ALL (comes with clips)
    59110FE151 & CLIPS 59122FA010X4 Impreza STI
    2006 Body, Fender Liners FENDER LINER LEFT FRONT FOR 2006 IMPREZA STI SEDAN ALL (comes with clips)
    57742FE000MJ Impreza STI
    2004-2005 Body, Front End AIR DAM SKIRT RIGHT passengers SIDE FOR 2004-2005 IMPREZA STI prepainted in Crystal Gray Metalic (item 4) comes with one clip
    57742FE000PG Impreza STI
    2004-2005 Body, Front End AIR DAM SKIRT RIGHT passengers SIDE FOR 2004-2005 IMPREZA STI prepainted in World Rally Blue (item 4) comes with one clip
    57742FE000TG Impreza STI
    2004-2005 Body, Front End AIR DAM SKIRT RIGHT passengers SIDE FOR 2004-2005 IMPREZA STI prepainted in Premium Silver (item 4) comes with one clip
    57742FE000VO Impreza STI
    2004 Body, Front End AIR DAM SKIRT RIGHT passengers SIDE FOR 2004 IMPREZA STI prepainted in Graphite Black Mica (item 4) comes with one clip
    57742FE000WG Impreza STI
    2004-2005 Body, Front End AIR DAM SKIRT RIGHT passengers SIDE FOR 2004-2005 IMPREZA STI prepainted in Pure White (item 4) comes with one clip
    57742FE000VW Impreza STI
    2005 Body, Front End AIR DAM SKIRT RIGHT passengers SIDE FOR 2005 IMPREZA STI prepainted in Obsidian Black Pearl (item 4) comes with one clip
    57742FE010MJ Impreza STI
    2004-2005 Body, Front End AIR DAM SKIRT LEFT drivers SIDE FOR 2004-2005 IMPREZA STI prepainted in Crystal Gray Metalic (item 4) comes with one clip
    57742FE010PG Impreza STI
    2004-2005 Body, Front End AIR DAM SKIRT LEFT drivers SIDE FOR 2004-2005 IMPREZA STI prepainted in World Rally Blue (item 4) comes with one clip
    57742FE010TG Impreza STI
    2004-2005 Body, Front End AIR DAM SKIRT LEFT drivers SIDE FOR 2004-2005 IMPREZA STI prepainted in Premium Silver (item 4) comes with one clip
    57742FE010VO Impreza STI
    2004 Body, Front End AIR DAM SKIRT LEFT drivers SIDE FOR 2004 IMPREZA STI prepainted in Graphite Black Mica (item 4) comes with one clip
    57742FE010WG Impreza STI
    2004-2005 Body, Front End AIR DAM SKIRT LEFT drivers SIDE FOR 2004-2005 IMPREZA STI prepainted in Pure White (item 4) comes with one clip
    57742FE010VW Impreza STI
    2005 Body, Front End AIR DAM SKIRT LEFT drivers SIDE FOR 2005 IMPREZA STI prepainted in Obsidian Black Pearl (item 4) comes with one clip
    53060FE041 Impreza STI
    2004-2005 Body, Front End UPPER RADIATOR PANEL FOR 2004-2005 IMPREZA STI ALL (item F)
    53020FE100 Impreza STI
    2004-2005 Body, Front End PANEL FOR RADIATOR SUPPORT RIGHT passengers SIDE FOR 2004-2005 IMPREZA STI (item A)
    53020FE110 Impreza STI
    2004-2005 Body, Front End PANEL FOR RADIATOR SUPPORT LEFT drivers SIDE FOR 2004-2005 IMPREZA STI (item E)
    53040FE002 Impreza STI
    2004-2007 Body, Front End STAY, HOOD LOCK FOR 2002-2007 IMPREZA STI ALL
    53060FE021 Impreza STI
    2004-2005 Body, Front End LOWER RADIATOR SUPPORT CORE FOR 2004-2005 IMPREZA STI (item D)
    91021FE070PG Impreza STI
    2004-2007 Body, Moulding Left Quarter PROTECTOR OUTER LEFT drivers SIDE QUARTER MOULDING PRE-PAINTED IN WORLD RALLY BLUE MICA (item C outer piece only)
    91021FE070MJ Impreza STI
    2004-2007 Body, Moulding Left Quarter PROTECTOR OUTER LEFT drivers SIDE QUARTER MOULDING PRE-PAINTED IN CRYSTAL GRAY METALIC (item C outer piece only)
    91016FE090 Impreza STI
    2004-2007 Body, Moulding Left Quarter MOULDING REAR LEFT RUBBER WHEEL ARCH FOR 2004-2007 IMPREZA STI SEDAN ONLY (item C) is the inner skinnier moulding in illustration
    91022FE010 Impreza STI
    2004-2007 Body, Moulding Left Quarter PROTECTOR FOR LEFT drivers SIDE REAR FOR 2004-2007 IMPREZA STI SEDANS ALL (item D) DOGLEG MOULDING in front of rear wheel with clip
    91021FE070VW Impreza STI
    2004-2007 Body, Moulding Left Quarter PROTECTOR OUTER LEFT drivers SIDE QUARTER MOULDING PRE-PAINTED IN OBSIDIAN BLACK PEARL (item C outer piece only)
    91021FE070TG Impreza STI
    2004-2005 Body, Moulding Left Quarter PROTECTOR OUTER LEFT drivers SIDE QUARTER MOULDING PRE-PAINTED IN PREMIUM SILVER (item C outer piece only)
    91021FE070WG Impreza STI
    2004-2007 Body, Moulding Left Quarter PROTECTOR OUTER LEFT drivers SIDE QUARTER MOULDING PRE-PAINTED IN PURE WHITE (item C outer piece only)
    96051FE030PG Impreza STI
    2004-2006 Body, Moulding Left Rocker MOULDING LOWER ROCKER LEFT drivers SIDE, FOR 2004-2006 IMPREZA STI SEDAN (Prepainted in Blue Mica) with clips
    96051FE030TG Impreza STI
    2004-2005 Body, Moulding Left Rocker MOULDING LOWER ROCKER LEFT drivers SIDE, FOR 2004-2005 IMPREZA STI SEDAN (Prepainted in Premium Silver) with clips
    96051FE030VO Impreza STI
    2004 Body, Moulding Left Rocker MOULDING LOWER ROCKER LEFT drivers SIDE, FOR 2004 IMPREZA STI SEDAN (Prepainted in Graphite Black) with clips
    96051FE030WG Impreza STI
    2004-2005 Body, Moulding Left Rocker MOULDING LOWER ROCKER LEFT drivers SIDE, FOR 2004-2006 IMPREZA STI SEDAN (Prepainted in Pure White) with clips
    96051FE030MJ Impreza STI
    2005-2006 Body, Moulding Left Rocker MOULDING LOWER ROCKER LEFT drivers SIDE, FOR 2005-2006 IMPREZA STI SEDAN (Prepainted in Crystal Gray Metalic) with clips
    96051FE030VW Impreza STI
    2005-2006 Body, Moulding Left Rocker MOULDING LOWER ROCKER LEFT drivers SIDE, FOR 2005-2006 IMPREZA STI SEDAN (Prepainted in Obsidian Black Pearl) with clips
    96051FE030MA Impreza STI
    2006 Body, Moulding Left Rocker MOULDING LOWER ROCKER LEFT drivers SIDE, FOR 2006 IMPREZA STI SEDAN (Prepainted in Grey Metalic) with clips NOTE there are two different Grays in 2006
    91016FE080 Impreza STI
    2004-2007 Body, Moulding Right Quarter MOULDING REAR RIGHT passengers side RUBBER WHEEL ARCH FOR 2004-2007 IMPREZA STI SEDAN ONLY (item C) is the inner skinnier moulding in illustration
    91022FE000 Impreza STI
    2004-2007 Body, Moulding Right Quarter PROTECTOR FOR RIGHT passengers SIDE REAR FOR 2004-2007 IMPREZA STI SEDANS ALL (item D) DOGLEG MOULDING in front of rear wheel with clip
    91021FE060PG Impreza STI
    2004-2007 Body, Moulding Right Quarter PROTECTOR OUTER RIGHT passengers SIDE QUARTER MOULDING PRE-PAINTED IN WORLD RALLY BLUE MICA (item C outer piece only)
    91021FE060MJ Impreza STI
    2004-2007 Body, Moulding Right Quarter PROTECTOR OUTER RIGHT passengers SIDE QUARTER MOULDING PRE-PAINTED IN CRYSTAL GRAY METALLIC (item C outer piece only)
    91021FE060TG Impreza STI
    2004-2005 Body, Moulding Right Quarter PROTECTOR OUTER RIGHT passengers side QUARTER MOULDING PRE-PAINTED IN PREMIUM SILVER (item C outer piece only)
    91021FE060VW Impreza STI
    2004-2007 Body, Moulding Right Quarter PROTECTOR OUTER RIGHT passengers SIDE QUARTER MOULDING PRE-PAINTED IN OBSIDIAN BLACK PEARL (item C outer piece only)
    91021FE060WG Impreza STI
    2004-2007 Body, Moulding Right Quarter PROTECTOR OUTER RIGHT passengers SIDE QUARTER MOULDING PRE-PAINTED IN PURE WHITE (item C outer piece only)
    96051FE020PG Impreza STI
    2004-2006 Body, Moulding Right Rocker MOULDING LOWER ROCKER RIGHT passengers SIDE, FOR 2004-2006 IMPREZA STI SEDAN (Prepainted in Blue Mica) with clips
    96051FE020TG Impreza STI
    2004-2005 Body, Moulding Right Rocker MOULDING LOWER ROCKER RIGHT passengers SIDE, FOR 2004-2005 IMPREZA STI SEDAN (Prepainted in Premium Silver) with clips
    96051FE020VO Impreza STI
    2004 Body, Moulding Right Rocker MOULDING LOWER ROCKER RIGHT passengers SIDE, FOR 2004 IMPREZA STI SEDAN (Prepainted in Graphite Black) with clips
    96051FE020WG Impreza STI
    2004-2005 Body, Moulding Right Rocker MOULDING LOWER ROCKER RIGHT passengers SIDE, FOR 2004-2006 IMPREZA STI SEDAN (Prepainted in Pure White) with clips
    96051FE020MJ Impreza STI
    2005-2006 Body, Moulding Right Rocker MOULDING LOWER ROCKER RIGHT passengers SIDE, FOR 2005-2006 IMPREZA STI SEDAN (Prepainted in Crystal Gray Metalic) with clips
    96051FE020VW Impreza STI
    2005-2006 Body, Moulding Right Rocker MOULDING LOWER ROCKER RIGHT passengers SIDE, FOR 2005-2006 IMPREZA STI SEDAN (Prepainted in Obsidian Black Pearl) with clips
    96051FE020MA Impreza STI
    2006 Body, Moulding Right Rocker MOULDING LOWER ROCKER RIGHT passengers SIDE, FOR 2006 IMPREZA STI SEDAN (Prepainted in Grey Metalic) with clips NOTE there are two different Grays in 2006
    61051AE001ML Impreza STI
    2004-2006 Door Handles INNER DOOR HANDLE RIGHT passengers SIDE FOR 2004-2006 IMPREZA STI (chrome type) (item 12)
    Moderating YOU
    Verdugo's Avatar
    Jan 2002
    Sea-Town, WA
    61051AE011ML Impreza STI
    2004-2006 Door Handles INNER DOOR HANDLE LEFT drivers SIDE FOR 2004-2006 IMPREZA STI (chrome type) (item 12)
    61032FE040 Impreza STI
    2004 Door Latches & Actuators LATCH & ACTUATOR ASSEMBLY RIGHT passengers SIDE FRONT DOOR FOR 2004 IMPREZA STI (items 1 & 3)
    61032FE041 Impreza STI
    2005 Door Latches & Actuators LATCH & ACTUATOR ASSEMBLY RIGHT passengers SIDE FRONT DOOR FOR 2005 IMPREZA STI ALL (items 1 & 3)
    61032FE050 Impreza STI
    2004 Door Latches & Actuators LATCH & ACTUATOR ASSEMBLY LEFT drivers SIDE FRONT DOOR FOR 2004 IMPREZA STI ALL (items 1 & 3)
    61032FE051 Impreza STI
    2005-2006 Door Latches & Actuators LATCH & ACTUATOR ASSEMBLY LEFT drivers SIDE FRONT DOOR FOR 2005-2006 IMPREZA STI ALL (items 1 & 3)
    61100FE000 Impreza STI
    2004-2006 Door Latches & Actuators ACTUATOR ASSEMBLY RIGHT passengers SIDE FRONT DOOR FOR 2004-2006 IMPREZA STI ALL (item 3)
    61100FE010 Impreza STI
    2004-2006 Door Latches & Actuators ACTUATOR ASSEMBLY LEFT drivers SIDE FRONT DOOR FOR 2004-2006 IMPREZA STI ALL(item 3)
    61031FE020 Impreza STI
    2004 Door Latches & Actuators LATCH & BRACKET ASSEMBLY RIGHT passengers SIDE FRONT DOOR FOR 2004 IMPREZA STI ALL (item 1)
    61031FE021 Impreza STI
    2005 Door Latches & Actuators LATCH & BRACKET ASSEMBLY RIGHT passengers SIDE FRONT DOOR FOR 2005 IMPREZA STI ALL (item 1)
    61031FE030 Impreza STI
    2004 Door Latches & Actuators LATCH & BRACKET ASSEMBLY LEFT drivers SIDE FRONT DOOR FOR 2004 IMPREZA STI ALL(item 1)
    61031FE031 Impreza STI
    2005-2006 Door Latches & Actuators LATCH & BRACKET ASSEMBLY LEFT drivers SIDE FRONT DOOR FOR 2005-2006 IMPREZA STI ALL(item 1)
    61034FE001 Impreza STI
    2004-2007 Door Latches & Actuators LATCH & BRACKET ASSEMBLY RIGHT passengers SIDE REAR DOOR FOR 2004-2007 IMPREZAS STI SEDAN ALL (item 1) actuator is seperate item
    61034FE011 Impreza STI
    2004-2007 Door Latches & Actuators LATCH & BRACKET ASSEMBLY LEFT drivers SIDE REAR DOOR FOR 2004-2007 IMPREZAS STI SEDAN ALL (item 1) actuator is seperate item
    61100FE040 Impreza STI
    2004-2007 Door Latches & Actuators ACTUATOR ASSEMBLY RIGHT passengers SIDE REAR DOOR FOR 2004-2007 IMPREZA STI SEDANS (item 3)
    61100FE050 Impreza STI
    2004-2007 Door Latches & Actuators ACTUATOR ASSEMBLY LEFT drivers SIDE REAR DOOR FOR 2004-2007 IMPREZA STI SEDAN (item 3)
    Brakes :
    27540AE000 Impreza STI
    2004-2005 Brakes, ABS Sensor SENSOR ABS FRONT RIGHT passengers side FOR 2004-2005 IMPREZA STI (item 1)
    27540AE010 Impreza STI
    2004-2005 Brakes, ABS Sensor SENSOR ABS FRONT LEFT drivers side FOR 2004-2005 IMPREZA STI (item 1)
    27540FE040 Impreza STI
    2004-2005 Brakes, ABS Sensor SENSOR ABS REAR RIGHT passengers side FOR 2004-2005 IMPREZA STI (item 2)
    27540FE050 Impreza STI
    2004-2005 Brakes, ABS Sensor SENSOR ABS REAR LEFT drivers side FOR 2004-2005 IMPREZA STI (item 2)
    26292FE022 Impreza STI
    2004-2006 Brakes, Front Calipers CALIPER UNIT NEW ONLY RIGHT FRONT (passenger side) FOR 2004-2006 IMPREZA STI 2.57 (pads are seperate) item 13
    26292FE030 Impreza STI
    2004-2006 Brakes, Front Calipers CALIPER UNIT NEW ONLY LEFT FRONT (drivers side) FOR 2004-2006 IMPREZA STI 2.57 (pads are seperate) item 13
    26300FE000 Impreza STI
    2004 Brakes, Front Discs BRAKE DISC FRONT ROTOR FOR 2004 IMPREZA STI ONLY item 1
    26300FE070 Impreza STI
    2005-2007 Brakes, Front Discs BRAKE DISC FRONT ROTOR FOR 2005-2007 IMPREZA STI ONLY item 1
    26296FE100 Impreza STI
    2004-2007 Brakes, Front Pads OEM FRONT BRAKE PAD SET FOR 2004-2006 IMPREZA STI & 2007 STI (non STI L) WITH SHIMS & HDWR
    26692FE001 Impreza STI
    2004-2006 Brakes, Rear Calipers CALIPER REMAN UNIT RIGHT REAR (passenger side) FOR 2004-2006 IMPREZA STI 2.57 ALL (pads seperate)
    26692FE011 Impreza STI
    2004-2006 Brakes, Rear Calipers CALIPER REMAN UNIT LEFT REAR (drivers side) FOR 2004-2006 IMPREZA STI 2.57 ALL (pads seperate)
    26700FE000 Impreza STI
    2004 Brakes, Rear Discs BRAKE DISC REAR ROTOR FOR 2004 IMPREZA STI ONLY
    26700FE050 Impreza STI
    2005-2006 Brakes, Rear Discs BRAKE DISC REAR ROTOR FOR 2005-2006 IMPREZA STI ONLY
    26696FE080 Impreza STI
    2004-2006 Brakes, Rear Pads SUBARU BRAKE PAD SET REAR , For 2004-2006 STI ONLY, includes shims & hardware
    27550FE000 Impreza STI
    2004-2006 Brakes, Tone Wheels TONE WHEEL REAR FOR 2004-2006 IMPREZA STI ONLY FITS BOTH LEFT & RIGHT (ITEM 3)
    26001FE030ML Impreza STI
    2004 Emergency Brake LEVER HAND BRAKE ASSEMBLY FOR 2004 IMPREZA STI MODELS
    Clutch :
    CLUTCHKIT 860 610 130 Impreza STI
    2004 Clutch Clutch Kit OEM for 2004 IMPREZA STI ONLY Includes Disc, cover & bearing, see items B,C & D in picture
    CLUTCHKIT 920 670 130 Impreza STI
    2005 Clutch Clutch Kit OEM for 2005 IMPREZA STI ONLY Includes Disc, cover & bearing, see items B,C & D in picture
    12310AA340 Impreza STI
    2004-2005 Clutch FLYWHEEL ASSEMBLY FOR 2004-2005 IMPREZA STI 2.57 M/T (item A&B)
    30620AA090 Impreza STI
    2004-2006 Clutch CLUTCH SLAVE CYLINDER FOR 2004-2006 IMPREZA STI 2.57 ONLY(item A)
    Dash & Glove Box :
    66065FE190 Impreza STI
    2004 Dash & Glove Box CENTER TRIM BEZEL LOWER CONTROLS SURROUND FOR 2004 IMPREZA STI ALL (item 19)
    66067FE000 Impreza STI
    2005-2006 Dash & Glove Box CENTER TRIM BEZEL LOWER CONTROLS SURROUND FOR 2005-2006 IMPREZA STI ALL (item 19) dark metal color
    66128AE000 Impreza STI
    2004-2006 Dash & Glove Box POCKET LOWER DASH FOR 2004-2006 IMPREZA STI ALL (item 21)
    Moderating YOU
    Verdugo's Avatar
    Jan 2002
    Sea-Town, WA
    Engine :
    23700AA540 Impreza STI
    2004-2005 Engine Parts, Alternator ALTERNATOR ASSEMBLY FOR 2004-2005 IMPREZA STI 2.57 ALL
    22433AA480 Impreza STI
    2004-2007 Engine Parts, Coil COIL PACK FOR 2004-2007 IMPREZA 2.57 TURBO STI ONLY (Car uses four, one at each plug)
    45131FE030 Impreza STI
    2004-2006 Engine Parts, Cooling Fan & Motor MOTOR ASSEMBLY FOR RADIATOR FAN FOR 2004-2006 IMPREZA STI 2.57 TURBO ONLY (item 15)
    45121FE001 Impreza STI
    2004-2006 Engine Parts, Cooling Fan & Motor FAN FOR RADIATOR FOR 2004-2006 ALL IMPREZAS
    45122FE030 Impreza STI
    2004-2005 Engine Parts, Cooling Fan & Motor SHROUD FOR RADIATOR FAN FOR 2004-2005 IMPREZA STI 2.57 TURBOS ONLY (item 14)
    2006 Engine Parts, Cooling Fan & Motor SHROUD FOR RADIATOR FAN FOR 2006 IMPREZAS ALL MOTORS (item 14)
    45150AE000 Impreza STI
    2004-2006 Engine Parts, Cooling Fan & Motor TANK FOR RADIATOR FOR 2004- 2006 IMPREZAS ALL
    21200AA072 & 21236AA010 Impreza STI
    2004-2006 Engine Parts, Cooling T Stats THERMOSTAT & GASKET FOR IMPREZA STI 2.57 ALL (Items 24&25)
    11060AA061 Impreza STI
    2004-2007 Engine Parts, Cooling T Stats HOUSING FOR THERMOSTAT FOR 2004-2007 IMPREZA STI 2.57 TURBOS (item 23)
    21111AA240 & 21114AA010 Impreza STI
    2004-2005 Engine Parts, Cooling WaterPumps WATERPUMP & GASKET FOR 2004-2005 STI MODEL 2.57 TURBO (items 21&22)
    45161FE050 Impreza STI
    2004-2006 Engine Parts, Cooling& Hoses HOSE,UPPER RADIATOR FOR 2004-2006 IMPREZA STI 2.57 (item 9) with 2 clamps
    45161AE020 Impreza STI
    2004-2006 Engine Parts, Cooling& Hoses HOSE, LOWER RADIATOR FOR 2004-2006 IMPREZA STI 2.57 (item 10) with 2 clamps
    ST451624S000 Impreza STI
    2004 Engine Parts, Cooling& Hoses OPTIONAL UPGRADE SPT STYLE RADITOR HOSE SET FOR 2004 IMPREZA STI
    11039AB650 Impreza STI
    2004-2005 Engine Parts, Cylinder Head CYLINDER HEAD NEW RIGHT SIDE FOR 2004-2005 IMPREZA STI 2.57 ONLY (comes bare without valves etc.)
    11063AB120 Impreza STI
    2004-2005 Engine Parts, Cylinder Head CYLINDER HEAD NEW LEFT SIDE FOR 2004-2005 IMPREZA STI 2.57 ONLY (comes bare without valves etc.)
    10105AA590 Impreza STI
    2004-2006 Engine Parts, Engine Gasket Set ENGINE GASKET KIT COMPLETE FOR 2004-2006 IMPREZA STI 2.57 ALL includes headgasket set, engine seals, orings, washers & gaskets (this kit does not include valve cover gaskets)
    22060AA111 Impreza STI
    2004-2006 Engine Parts, Knock Sensor KNOCK SENSOR FOR 2004-2006 IMPREZA STI 2.57 TURBO ALL
    22680AA310 Impreza STI
    2004-2006 Engine Parts, Mass Air MASS AIR FLOW METER FOR 2004-2006 IMPREZA ALL (item A)
    11140AA120 Impreza STI
    2004-2005 Engine parts, Oil DipStick DIPSTICK FOR ENGINE OIL FOR 2004-2005 IMPREZA STI 2.57 ALL (item 18)
    15144AA011 Impreza STI
    2004-2006 Engine parts, Oil DipStick GUIDE FOR DIPSTICK ENGINE OIL FOR 2004-2006 IMPREZA STI 2.57 (item 19)
    11109AA131 Impreza STI
    2004-2006 Engine parts, Oil Pan OIL PAN WITH PLUG FOR 2004-2006 IMPREZA STI 2.57 ALL item 17
    15010AA280 Impreza STI
    2004-2006 Engine Parts, Oil Pump OIL PUMP FOR 2004-2006 IMPREZA 2.57 STI ALL
    004403007 Impreza STI
    2004-2007 Engine Parts, Oil Pump FUJI BOND SILICONE GASKET MAKER 8.8 oz TUBE
    21191KA000 Impreza STI
    2004-2006 Engine Parts, Oil Seals ORING at BOTTOM OF OIL FILLER NECK FOR 2004-2006 IMPREZA STI 2.57 ONLY
    806786040 Impreza STI
    2004-2006 Engine Parts, Oil Seals REAR MAIN SEAL FOR 2004-2006 IMPREZA STI
    2004-2007 Engine Parts, Oil Seals FUJI BOND SILICONE GASKET MAKER 8.8 oz TUBE
    45111FE102 Impreza STI
    2004-2006 Engine Parts, Radiators OEM RADIATOR ASSEMBLY FOR 2004-2006 IMPREZA STI 2.57 MANUAL TRANS ALL (item 1)
    22641AA211 Impreza STI
    2004-2007 Engine Parts, Sensor O2 SENSOR FRONT AIR FUEL RATIO FOR 2004-2006 IMPREZA STI 2.57 ALL (item G at left of picture plugs into front exhaust)
    22690AA520 Impreza STI
    2004-2007 Engine Parts, Sensor O2 SENSOR OXYGEN ASSEMBLY FOR IMPREZA 2004-2007 2.57 STI ALL (item N)
    13570AA044 Impreza STI
    2004-2006 Engine Parts, T Belt Covers & Slings COVER, T BELT CENTER FRONT FOR 2004-2006 IMPREZA STI 2.57 TURBO (item 4)
    13572AA092 Impreza STI
    2004-2006 Engine Parts, T Belt Covers & Slings COVER TIMING BELT RIGHT SIDE FRONT (passenger side) FOR 2004-2006 IMPREZA STI 2.57 TURBO (item 2)
    13573AA131 Impreza STI
    2004-2006 Engine Parts, T Belt Covers & Slings TIMING BELT COVER RIGHT REAR (passengers side) FOR 2004-2006 IMPREZA STI 2.57 TURBOS (item 5)
    13574AA094 Impreza STI
    2004-2006 Engine Parts, T Belt Covers & Slings COVER TIMING BELT LEFT SIDE FRONT (drivers side) FOR 2004-2006 IMPREZA STI 2.57 TURBO ONLY (item 3)
    13575AA130 Impreza STI
    2004-2006 Engine Parts, T Belt Covers & Slings TIMING BELT COVER LEFT REAR (drivers side) FOR 2004-2006 IMPREZA STI 2.57 TURBOS (item 6)
    13581AA050 Impreza STI
    2004-2006 Engine Parts, T Belt Covers & Slings UPPER SLING for Center Timing Belt Cover for 2004-2006 IMPREZA STI 2.57 TURBO ALL (item 7)
    13594AA000 Impreza STI
    2004-2006 Engine Parts, T Belt Covers & Slings SEAL LOWER FOR CENTER TBELT COVER FOR 2004-2006 IMPREZA STI 2.57 TURBOS ONLY (item 8)
    13320AA001 Impreza STI
    2004-2006 Engine Parts, T Belt Pulleys & Tensioners SPROCKET COMPLETE CAMSHAFT INTAKE RIGHT SIDE FOR 2004-2006 IMPREZA STI TURBO 2.57 (item H)
    13049AA041 Impreza STI
    2004-2006 Engine Parts, T Belt Pulleys & Tensioners SPROCKET COMPLETE CAMSHAFT EXHAUST RIGHT SIDE FOR 2004-2006 IMPREZA STI TURBO 2.57 (item L)
    13054AA033 Impreza STI
    2004-2006 Engine Parts, T Belt Pulleys & Tensioners SPROCKET COMPLETE CAMSHAFT EXHAUST LEFT SIDE FOR 2004-2006 IMPREZA STI 2.57 TURBO (item K)
    13322AA001 Impreza STI
    2004-2006 Engine Parts, T Belt Pulleys & Tensioners SPROCKET COMPLETE CAMSHAFT INTAKE LEFT SIDE FOR 2004-2006 IMPREZA STI 2.57 TURBO (item J)
    13021AA141 Impreza STI
    2004-2006 Engine Parts, T Belt Pulleys & Tensioners SPROCKET FOR CRANK PULLEY FOR 2004-2006 IMPREZA STI 2.57 TURBO (item G) goes behind Harmonic Balancer
    12305AA251 & 12369AA011 & 804505060 Impreza STI
    2004-2006 Engine Parts, T Belt Pulleys & Tensioners PULLEY CRANKSHAFT, BOLT & KEYWAY FOR 2004-2006 IMPREZA STI 2.57 TURBO ALL (item 1)
    13073AA142 Impreza STI
    2004-2006 Engine Parts, T Belt Pulleys & Tensioners IDLER FOR 2004-2006 IMPREZA STI 2.57 TURBOS ONLY (items A&B) (same part used both upper & lower right)
    13073AA230 Impreza STI
    2004-2006 Engine Parts, T Belt Pulleys & Tensioners IDLER PULLEY FOR 2004-2006 IMPREZA STI 2.57 TURBO (in illustration this idler goes in to the left of item G facing the motor on the tensioner bracket) it is small
    13085AA080 Impreza STI
    2004-2006 Engine Parts, T Belt Pulleys & Tensioners PULLEY IDLER (WITH TEETH) FOR 2004-2006 IMPREZA STI 2.57 TURBO (item E)
    13028AA240 Impreza STI
    2004-2007 Engine Parts, Timing Belt TIMING BELT FORV 2004-2007 IMPREZA STI 2.57 (TURBO) (item A)
    ST130284S000 Impreza STI
    2004-2006 Engine Parts, Timing Belt TIMING BELT, STI TYPE FOR 2004-2006 STI (optinal upgrade belt for 2.57 STI)
    14411AA620 Impreza STI
    2007 Engine Parts, Turbo Charger TURBO CHARGER ASSEMBLY FOR 2007 IMPREZA STI 2.57 (item 8)
    14411AA572 Impreza STI
    2004-2006 Engine Parts, Turbo Charger TURBO CHARGER ASSEMBLY FOR 2004-2006 IMPREZA STI 2.57 (item 8)
    21820AA280 Impreza STI
    2004-2006 Engine Parts, Turbo Charger INTERCOOLER ASSEMBLY FOR EARLY 2004-2007 IMPREZA STI 2.57 (item 1)
    21896AA010X2 Impreza STI
    2004-2007 Engine Parts, Turbo Charger GASKET SET (2) FOR INTERCOOLER FOR 2004-2007 IMPREZA STI (items 23)
    14471AA143 & 21896AA110 Impreza STI
    2004-2007 Engine Parts, Turbo Charger AIR BYPASS VALVE ASSEMBLY & GASKET FOR 2004-2007 IMPREZA STI 2.57 (items 5 & 6)
    VCG STI KIT Impreza STI
    2004-2007 Engine Parts, Valve Cover Gskts VALVE COVER GASKET KIT FOR 2004-2007 IMPREZA STI 2.57 (items A&B) includes left & right gaskets and 4 inner gaskets 13270AA190 13272AA140 13293AA051X4
    13207AA120 Impreza STI
    2004-2006 Engine Parts, Valve Seals SEAL FOR INTAKE VALVE FOR 2004-2006 IMPREZA STI 2.57 ALL (all engines uses eight total)
    13211AA110 Impreza STI
    2004-2006 Engine Parts, Valve Seals SEAL FOR EXHAUST VALVE FOR 2004-2006 IMPREZA STI 2.57 (all engines uses eight total)(item D)
    13271AA371 Impreza STI
    2004-2006 Engine Parts, Valves INTAKE VALVE FOR 2004-2006 IMPREZA STI 2.57 ONLY (sold individually, this engine uses eight total) (item C) FOR CARS PRODUCED AFTER 2 OF 2004
    13201AA400 Impreza STI
    2004 Engine Parts, Valves INTAKE VALVE FOR 2004 IMPREZA STI 2.57 ONLY (sold individually, this engine uses eight total) (item C) FOR CARS PRODUCED UPTO 1 OF 2004
    13211AA411 Impreza STI
    2004-2006 Engine Parts, Valves EXHAUST VALVE FOR 2004 -2006 IMPREZA STI 2.57 (sold individually, this engine uses eight total) (item A)
    806933010X2 Impreza STI
    2004-2006 Engine Parts, Water Pipe ORINGS FOR WATER PIPE FOR 2004-2006 IMPREZA STI (items A) both
    56410FE211 &CLIPS 57728AC090X4 Impreza STI
    2004-2006 Engine Under Covers UNDER COVER FRONT FULL FOR 2004-2006 IMPREZA STI comes with four push-in clips
    A0910AS100 Impreza STI
    2004-2007 Engine, Block Heater Add on ENGINE BLOCK HEATER WITH INSTRUCTIONS
    23300AA420 Impreza STI
    2004-2007 Engine, Starter STARTER ASSEMBLY NEW FOR 2004-2007 IMPREZA STI ALL
    Moderating YOU
    Verdugo's Avatar
    Jan 2002
    Sea-Town, WA
    Exhaust :
    44104FE090 & 44022AA150 Impreza STI
    2004-2006 Exhaust, Converters JOINT PIPE & PRE CAT (upto Turbo unit) FOR 2004-2006 IMPREZA STI 2.57 ALL (items H&K at left aims downward) (with inlet gasket)
    44102FE170 & 44022AA180 Impreza STI
    2004-2006 Exhaust, Converters CENTER PIPE & FRONT CAT ASSEMBLY (out of Turbo unit) FOR 2004-2006 IMPREZA STI 2.57 (item M&L at left) (with outlet gasket)
    44101FE090 & 44022AA122 & 44011FE000 Impreza STI
    2004-2005 Exhaust, Converters MIDPIPE & CAT ASSEMBLY FOR 2004-2005 IMPREZA STI 2.57 (items P&Q)
    2004-2006 Exhaust, Front Pipe GASKET (turbo outlet) FOR TOP OF UP PIPE FOR 2004-2006 IMPREZA STI 2.57 turbo only (item L at top left)
    2004-2006 Exhaust, Front Pipe GASKET (turbo inlet) FOR TOP OF SHORT JOINT PIPE FOR 2004-2006 IMPREZA STI 2.57 turbo only (item K at top left)
    44201FE020 Impreza STI
    2004-2005 Exhaust, MidPipe MIDPIPE ASSEMBLY FOR 2004-2005 IMPREZA STI 2.57 (item R)
    SOA8377900 Impreza STI
    2004-2007 Exhaust, Muffler PERFORMANCE EXHAUST SYSTEM-CAT-BACK (SPT) for 2004-2007 IMPREZA STI ONLY.Large diameter, 3 inch stainless steel replaces stock mid pipe and muffler, resulting in enhanced exhaust sound and performance.
    44300FE180 & 44022AA131 Impreza STI
    2004-2005 Exhaust, Muffler MUFFLER ASSEMBLY FOR 2004-2005 2.57 IMPREZA STI (with gasket) (items T&S far right of photo)
    44300FE240 & 44022AA131 Impreza STI
    2006 Exhaust, Muffler MUFFLER ASSEMBLY FOR 2006 IMPREZA STI 2.57(with gasket)
    P.S More to come Mon through Thurs . taking awhile to build the list by C89ZX7R.
    Registered User wRxOne's Avatar
    May 2002
    Vallejo, CA
    Armin are you on drugs? j/k... good info should make this a sticky when your done
    Nov 2005
    Central Florida
    + 1 for sticky
    good job man great info
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
    Moderator
    Jul 2003
    Maryland
    I vote Sticky icky icky on this one.
