blowing fuses
Results 1 to 3 of 3
This is a discussion on blowing fuses within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I installed a train horn recently and everything went fine. The compresser was working fine for a day then it ...
    Registered User boostin_ass's Avatar
    May 2005
    Roseville, CA
    blowing fuses
    I installed a train horn recently and everything went fine. The compresser was working fine for a day then it just started blowing the fuse from the battery to the compresser. I tryed a different ground, that worked for another day now its blowing the fuse again. Any suggestions?
    04 Java Black Pearl Wingless WRX:
    5% Tint all around, 10" windsheild strip, 2 pod gauge frame, Turbo and Volt Gauges, Tien S-tech Springs, Progress adj. Rear Sway Bar, Front and Rear Tower Braces, Sound System/DVD, Tsudo Cat-back exhaust, Black housing headlights, Invidia uppipe, Bosal Downpipe, Train Horn, Elbow Silencer Delete, DIY I/C Water Sprayer, 4300K H.I.D.'s
    Registered User krakkaplease's Avatar
    Jan 2007
    az
    what size fuse is it. get an amp clamp and see how many amps the compressor is drawing.
    May 2005
    Roseville, CA
    Quote Originally Posted by krakkaplease View Post
    i figured it out, the freakin piston came off the crank shaft thing and it was stuck so it was trying to hard to move it, im pissed only been on the car 3 days
