over heated??
Results 1 to 15 of 23
This is a discussion on over heated?? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; so i was driving to work today after lunch and cruising at about 70 +- and my car got hot ...
    Registered User lovetheboost121's Avatar
    Nov 2006
    Douglas, AZ
    Exclamation over heated??
    so i was driving to work today after lunch and cruising at about 70 +- and my car got hot all of a sudden, boiling hot, i pulled over let it cool for about 15-20 mins and limped back to work, now that it has been sitting for a while i started it and topped it off and now it seems to be doing fine. does anybody have any ideas as to what the problem was?
    Administrator
    May 2003
    Has the coolant system been opened recently?
    Nov 2006
    Douglas, AZ
    not that i know of
    Administrator
    May 2003
    Is your fan coming on when the car is hot?
    Nov 2006
    Douglas, AZ
    it was on when i stopped and this is the first time it has ever gotten hot since i became the owner
    Nov 2006
    Douglas, AZ
    anybody else have any ideas, water pump problems? head gasket?
    Administrator
    May 2003
    Quote Originally Posted by lovetheboost121 View Post
    Possibly a thermostat. How many miles are on your car, and how is your heat working?
    Registered User spoolinup's Avatar
    Dec 2006
    my guess is the thermostat, i'd start there. Something that out of nowhere seems like the t-stat stuck.
    Nov 2006
    Douglas, AZ
    but after it got hot it has been getting hot all the time now when driving it, it does not get hot at idle but as soon as i start driving it the temp starts going up. We replaced the t-stat and it still does it my budddy owns an auto shop and he drove it a couple times and it was getting hot intermittently and the car only has 56k on it and only 6k on the new motor (replaced before i bought it) we were thinking head gasket but there are no signs of it, no water in oil, no water bubbling out of fadiator when cap is off, so the only thing we can think of is the water pump, is there anything else it could be?
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    I had a problem with this after replacing coolant in the bugeye. Since the coolant system is pressurised, as much as a cup low on coolant can cause problems. I was 2 cups low on fluid after a timing belt replacement and had this problem even though it seemed full when I added coolant initially.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    Nov 2006
    Douglas, AZ
    i checked that and everything was fine had plenty of coolent
    Administrator
    May 2003
    Quote Originally Posted by Trainrex View Post
    not that i know of
    You said the coolant system hadn't been opened.
    Burp the system.
    Nov 2006
    Douglas, AZ
    it hadn't been opened until i got it to my buddies shop and we checked it out, added coolent and burped it, still had the problem so replaced the t-stat, and now still have the problem and both fans are working properly.
    Administrator
    May 2003
    1: Have you tested the coolant for hydrocarbons?
    2: Is the water pump leaking by the weep hole at all?
    3: AT what temperature is the fan coming on? (exactly. Plug into high end scanner for this info)
    4: Is the thermostat in backwards?
    5: Is the radiator showing any signs of blockage?
    6: How well is the heat working?
    Administrator
    May 2003
    Also, if the engine was replaced, the coolant system was opened.
