over heated?? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
This is a discussion on over heated?? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; 1: Have you tested the coolant for hydrocarbons? not yet, need to find somebody in town that can test it ...
    Registered User lovetheboost121's Avatar
    Nov 2006
    Douglas, AZ
    2: Is the water pump leaking by the weep hole at all? no signs of any leakage
    3: AT what temperature is the fan coming on? (exactly. Plug into high end scanner for this info) will know in a few minutes
    4: Is the thermostat in backwards? no
    5: Is the radiator showing any signs of blockage? no
    6: How well is the heat working? good now that t-stat has been changed and system has been burped
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    FYI you can have a plugged radiator and be impossible to tell. My old chevy ate 4 radiators before I got one that lasted. All were partially plugged even when using Deionized water.
    If the engine was replaced, certain shady shops pour coolant into oil drain pan and then pour back into radiator. If there were any metal shavings etc, it would cause a plug.
    And with the Subi being so finicky on coolant and since you've tried everything else...........points to a plugged radiator.
    Problem is subi has plastic end tanks, so there really is no boiling or testing for it being plugged. Just Replace.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    Nov 2006
    Douglas, AZ
    but wouldn't that cause the car to get hot even while idleing, because the only time it heats up is when i start going down the road, we let it idle for about 15 mins and it stayed at normal running temp.
  6. #19
    Jun 2006
    Nor Cal
    Quote Originally Posted by lovetheboost121 View Post
    Not necessarily.
    Depending on how much all the diagnosis and analizing costs, it might be cheaper and easier in the long run just to replace the radiator.
    If your coolant level is good, youve burped the system, replaced you t-stat, and both fans work properly, what else is there?
    Stock Radiator is about $240.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
  7. #20
    Nov 2006
    Douglas, AZ
    is there any way to test to find out for sure that it is the radiator?
  8. #21
    Jun 2006
    Nor Cal
    I've just always pulled the radiator and taken it to a shop. Most the time though they charge a $100 fee for cleaning the radiator out, which they'll do any way, and 60% of the time it doesn't work or only buys you till summer time. Since it has plastic end tanks they can only "flush" it not "boil" it, which is way less effective.
    Options:
    Worst case senario, you take it to the shop have it looked at, get charged $100 and still have to buy a new radiator= $340 total.
    Best case, $100 radiator flush works, at least for a while, =$100
    Or isn't the problem =$100 + more parts.
    Middle ground you buy a new radiator and put it in =$240.
    Or you say screw it and go with a performance aluminum one which is $???.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
  9. #22
    Nov 2006
    Douglas, AZ
    update: there was no air in the system and the radiator flowed fine
    Die Trying, Not Watching!!
    2002 Subaru wrx stage 2
    2000 Kawasaki KX250
    2004 Honda CRF450
  10. #23
    Nov 2006
    Douglas, AZ
    new update, removed water pump and when turning pulley side of the impeller shaft, impeller does not spin!!! new pump on the way. thanks for all your help guys!!
    2000 Kawasaki KX250
    2004 Honda CRF450
