oil drain plug leaks
Results 1 to 15 of 18
This is a discussion on oil drain plug leaks within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; after i change my oil on the 06 tr, the plug will leak after a couple of hours. the dealer ...
    Mar 2006
    after i change my oil on the 06 tr, the plug will leak after a couple of hours. the dealer does supply me with the washer that goes in between the plug and oil pan, but it stil leaks. anybody else have this problem?
    has anbody tried useing a FRAM oil filter? subaru ones are like 12 beans, i piked up a FRAM @ kragen for 9.99. i am a little hesitant about using it though. is there a difference in the subaru and the FRAM?
    06 CGM STi
    ERZ Downpipe, K and N Drop in filter.
    Welfare Mods:Silencer Delete
    05 Flame RED SRT-4
    [SIGPIC][/SIGPIC]
    Oct 2005
    Late Devonian
    I have, but it stopped when I tightened it more. The washer will begin to crush. It crushes so that you don't strip the threads, so don't bottom it out.
    SuperNova 06wrx4me's Avatar
    Jun 2006
    Nor Cal
    I am still using the OEM crush washer that came with my car when I first got it and have changed the oil 4 times myself with no leaks.
    The only time I used a subaru oil filter is when it came on the car. Since then I have used Fram and NAPA. If you change your oil regularly, every 3k or so, the brand of filter really doesnt matter much.
    2016 Challenger Scat Pack
    1973 Nova
    2014 Ford Fiesta ST <sold>
    COILOVER TABLE
    TURBO TABLE
    Mar 2006
    Quote Originally Posted by 06wrx4me View Post
    mine didn't even come with a washer.
    so the washer isn't really there to seal? its just there so you won't strip the threads? so i guess you dont even need the washer then right?
    06 CGM STi
    05 Flame RED SRT-4
    [SIGPIC][/SIGPIC]
    Jun 2006
    Nor Cal
    Quote Originally Posted by DTFH3030 View Post
    No you need the crush washer. Mine came with one as I think all Subis do. But they fall off when you accidently drop the drain plug in the oil drain pan.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    Mar 2006
    mine didn't. thats why i thought it was weird when i first changed my oil and the parts guy gave me a washer.
    06 CGM STi
    05 Flame RED SRT-4
    [SIGPIC][/SIGPIC]
    Jun 2006
    Nor Cal
    Yeah they leak without the washer.
    The guy we bought the shop bugeye from thought he cracked his oil pan. But after being on here I new it was just a missing washer.
    Yeah my subi dealer has them taped to the oil filter boxes
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    Q RayfieldsWRX's Avatar
    Oct 2002
    The Old Folks Home
    OP: Out of curiosity, what spec are you tightening the draing plug to? I think 33 lb-ft is the correct torque.
    --Ray
    "Bro ima get Bimota BB3 because expert. My parents have 911 turbo but awd won't let me launch, ima get 962 twin turbo Group C bro." -- SD_GR
    2013 Subaru BRZ Limited
    2002 Subaru WRX Bugeyebrid Wagon -- SOLD
    2002 Subaru WRX Sedan -- SOLD
    Oct 2005
    Late Devonian
    I could be wrong, but oil filters are supposed to work better once they've been on for a bit. Some prefer not to change it every time because it works better for the second 3K (or whatever).
    I don't recall ever paying $12 for a 2003 filter, but I do prefer the Subaru filters.
    Registered User dcpatters's Avatar
    Sep 2004
    Irvine, CA
    I had this problem. I replaced the crush washer and tourqued the plug again. No more leak. Sounds kind of crazy, but I did this withoug draining the oil again.
    Also, make sure the flat side of the crush washer is seated against the drain plug not the oil pan before re-installing.
    2008 Evo X GSR. Custom tuned, Works panel filter, Intercooler pipe upgrade, TBE.
    Jun 2006
    Nor Cal
    A filter never works as good as when it is new. True for oil, air and hydraulic
    Filters are rated for the Micron size of particle they will filter out. As long as you use a comperable Micron of filter to the stock one, shouldn't make a difference. Especially if you change oil regularly.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
    Nov 2006
    Richmond, Va
    I refuse to allow a fram filter on any of my 2 cars.
    http://svt4u2try.com | Myspace | Photos
    97 Cobra, 98 Z/28 hardtop
    Apr 2004
    Southeastern PA
    I have a very slight leak at the plug too - first time I ever have.
    Quote Originally Posted by dcpatters View Post
    Yes ... it does. Just how did you do this?
    I do not remember if I did this the last time.
    Mods & Pics
    Moderator GV27's Avatar
    Jun 2002
    Green Mountain, Colorado
    Holy balls! Is that 9.99 Canandian? Frams are about a third of that US around here. Either way they're garbage. Get a Purolator or a Wix.
    1990 Alfa Romeo Spider Veloce
    1993 Honda CBR600F2
    2002 WRX SportWagon *sold*
    Jun 2006
    Nor Cal
    Quote Originally Posted by GV27 View Post
    Its funny how in different parts of the US certain brands are more prevalent than others. In California its like hens teeth to find a purolator filter. Wix is a little more common, but even bosh filters are more common here.
    1973 Nova
    COILOVER TABLE
    TURBO TABLE
