Stage 2 OBD Code 06B3
Results 1 to 10 of 10
This is a discussion on Stage 2 OBD Code 06B3 within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I'm at work and had the check engine light come on right as I pulled in. All my Accessport stuff ...
    Registered User mattysrex's Avatar
    Dec 2006
    Somerset NJ
    I'm at work and had the check engine light come on right as I pulled in. All my Accessport stuff is at home ftl and I'm nervous about moving it. Anyone know what OBD code 06B3 means? I just put a new clutch in so I'm figuring it is smething minor, but since I just spend alot of $$ I'm leery of doing it again
    America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936
    Registered User pweizman's Avatar
    'Nati, Ohio
    http://www.scoobypedia.co.uk/index.p...odeDefinitions
    How did you read the code if your AP is at home?
    06B3 doesn't seem like a valid code. It should only be numeric.
    Maybe P0638?
    Patrick
    RSX-S
    Sold: '03 WRX Wagon (bugeyes rock!)
    Dec 2006
    Somerset NJ
    no, that was definitely the code and thats why I'm confused. I have the actual AP in the glovebox but all the others things ( like the map manager, instructin book, etc) is at home. I just got the car 2 months ago and am still getting used to the AP.
    'Nati, Ohio
    Did you check Cobb's website?
    Is the car acting funny?
    Later,
    Patrick
    RSX-S
    Dec 2006
    Somerset NJ
    I checked Cobb's website and couldnt find anything that matched up. The car hasn't been acting funny at all, besides getting used to a new clutch that far exceeds the stock (i put an EXEDY clutch in to replace the stock). It bucks a little bit shifting from 1st to 2nd but i think that's more "user error" than anything else. sort of at a loss here...not running hot, all the fluids are ok, no weird noises or anything like that
    Mar 2006
    in my srt its okay to drive as long as the CEL is'nt blinking, usually the check engine light will have something to do with emissioins, i dont know much about subarus though. i wouldn't worry about it too much as long as everything sounds okay and is running okay. is your gas cap screwed on right? you could take it to a local autozone and have the code read there.
    06 CGM STi
    ERZ Downpipe, K and N Drop in filter.
    Welfare Mods:Silencer Delete
    05 Flame RED SRT-4
    [SIGPIC][/SIGPIC]
    Dec 2006
    Somerset NJ
    i checked the gas cap and its on fine. i even called Cobb b/c the code isn't numeric; there's letters in it and it doesnt start with a P. I'll swing it by autozone tonight to see if they can help me out. i'm probably more paranoid than anything else but in the end i just want this light to go off
    Mar 2006
    Quote Originally Posted by mattysrex View Post
    reset the ecu, that should take care of the problem if its not consistent, you should be okay.
    06 CGM STi
    05 Flame RED SRT-4
    [SIGPIC][/SIGPIC]
    Dec 2006
    Somerset NJ
    thanks alot guys. i got it over to autozone and got the REAL CEL code - P0851: Neutral Switch Circuit Low Input. I reset the ECU and will wait to see if anything comes of it. Much appreciated!
    Dec 2006
    Somerset NJ
    Apparently this code relates to a transmission issue. just replaced my clutch 2 days ago (stock to Exedy OEM).
