Results 1 to 2 of 2
This is a discussion on Bucking at any speed any gear ??misfire??Whats wrong within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; EDIT: Fixed, turns out i wired the amp wrong. haha...
    Feb 2006
    Hockessin Delaware
    Nov 2005
    Central Florida
    Quote Originally Posted by rexspeedmaster View Post
    Ok Here is the thing. I posted a while ago that I had an idle problem and also bucking. I cleaned the IACV because of some advice I recieved. That helped the idle problem alot. Now I still have the bucking problem. I drove the car around for 2.5 miles and it was fine. I hit some boost up to about 10psi and no leaks or bad sounds or anything ran perfectly. Then a little way (.25 mile) down the road while i was in vacum i had one buck, felt like a fuel cut. I immediately turned around and headed home. It still bucked every one in a while even though I was hardly on the accelerater and always in vacum. What is wrong? Any ideas?
    check the ic piping for a leak
    All We'll Drive
    DIFFERENT STROKES
    POST WH0RE KING
