question about oil change - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 20 of 20
This is a discussion on question about oil change within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; First of all, the factory maintenanence manual recommends an oil change every 5k-7k miles. Also, mobil 1 syn oil is ...
    Registered User kreamern's Avatar
    Jan 2007
    NC
    First of all, the factory maintenanence manual recommends an oil change every 5k-7k miles. Also, mobil 1 syn oil is known to be good for at least 5k. It doesn't hurt the car to change it early but it does cost money and that hurts the car.
    The tires don't need to be rotated unless they wear unevenly.
    Nov 2006
    Richmond, Va
    Quote Originally Posted by kreamern View Post
    I am sorry but you are incorrect.
    Yes the manual states 1 thing, but just because an oil is good for such and such mileage, doesnt mean you should. Even on the bottle Mobil 1 states be sure to follow manufacturers guidelines.
    Tire rotations alone do not prevent uneven wear. They help with wear among all the other tires and keep the AWD from having issues over time with tires that have a variance in circumference. However once a tire is in an uneven wear pattern it is too late, you can't correct it.
    http://svt4u2try.com | Myspace | Photos
    97 Cobra, 98 Z/28 hardtop
    Jan 2007
    NC
    Quote Originally Posted by blackfang View Post
    I did not mean that tire rotation prevents uneven wear. I meant that if unless one set of tires(either the front or back) wears faster than the other, it does good to rotate them for many reasons.
  6. #19
    Registered User afbluesv1k's Avatar
    Apr 2006
    Buffalo, NY
    Sorry but with different brand tires, the treadware rating doesnt apply. It must be among the same brand tire. That is also a bad way to figure out when to rotate tires.
    Well good call on that and didnt know that they were specific to tire companies. But what I was getting at was with my winter tires that have a stiffer compund, I rotate them every 6K. But with my RE070 I rotate them every oil change at 3500 miles because they are a softer tire so the tread depth changes at a more drastic rate.
  7. #20
    Nov 2006
    Richmond, Va
    Quote Originally Posted by afbluesv1k View Post
    Yeah because the treadware rating is based on that brand tires base tire. They test all their tires verse the base one to figure out the rating. So a tire with a 300 rating isnt going to be the same among all brands because Goodyear didnt test their tire with BFG's base tire, they all use their own.
    I see where you went with the softer tire, which is correct. They will wear faster than a tire with a harder compound. I just didn't want other to think they can compare tire ratings and expect something from it.
