Results 1 to 3 of 3
This is a discussion on .1 bar of boost = 14 psi? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; This is a pretty stupid quiestion but is this right? Does anyone know if there is an easy way to ...
    Aug 2006
    Does anyone know if there is an easy way to switch my gauge to a PSI one?
    Moderator   Sasquatch's Avatar
    Apr 2004
    Southeastern PA
    That is more or less correct. 1 bar = 14.503 773 801 pound/square inch
    Check this site out: http://www.onlineconversion.com/pressure.htm
    Once you get used to reading in bar, you can do the psi conversion well enough in your head.
    Moderator for: Aftermarket Vendor & Installer Review / Detailing Forum / Engine Modifications / Exterior & Appearance
    New Member Hangout / Off Topic / Tri-State
    Mods & Pics
    Registered User vroompssh's Avatar
    Sep 2006
    nor cal
    yep
    wingless urban Grey metallic 06 wrx sedan
    Wingl3ss @lliance #14
