baffled by location of restrictor pill...
Results 1 to 10 of 10
This is a discussion on baffled by location of restrictor pill... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; since I got my car, I've noticed the location of the brass restrictor pill is on the wastegate acctuator side ...
    Registered User tsignr's Avatar
    Aug 2006
    Billings, MT
    since I got my car, I've noticed the location of the brass restrictor pill is on the wastegate acctuator side of the "T". Boost is normal, perhaps a little low. When I reverse the "T", so that the restrictor pill is nearest the turbo outlet, it will overboost in 2nd. I have no 3/16" mod and the wastegate is backed off all the way. Could this be caused by the wastegate/boost solenoid?
    Administrator
    May 2003
    The brass pill should be on the compressor side. Have the wastegate hoses been changed?
    Aug 2006
    Billings, MT
    Quote Originally Posted by Trainrex View Post
    I know, that's my dilemna. And no, everything appears to be factory.
    Administrator
    May 2003
    Normally a faulty FBC will cause low boost. What mods are you running?
    Aug 2006
    Billings, MT
    hks downpipe(I know, it sucks), perrin flat panel intake, perrin pulley and cobb access port stage 2.
    Administrator
    May 2003
    Quote Originally Posted by tsignr View Post
    With a stock turbo, that downpipe is just fine.
    Have you tried putting the pill in the correct position, and resetting the ECU?
    Aug 2006
    Billings, MT
    I have, I even made sure that the pill was set right and I could see through the hose and the pill itself. What else keeps the car from overboosting that might not be doing it's job?
    Administrator
    May 2003
    Possibly a stuck wastegate. When you undo the wastegate arm, does it move freely?
    Aug 2006
    Billings, MT
    I could check it again. What should it do? Should it be loose or stiff? Could it be stuck closed?
    Thanks for all the help by the way. I haven't found any posts w/ this particular problem.
    Administrator
    May 2003
    It could be stuck closed. When you detach it from the arm it should move freely.
