Results 1 to 4 of 4
This is a discussion on loss of power any suggestions? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; hey eveyone, im new to the forum, and i have a situation. like an idiot before reading up on it ...
    Dec 2006
    hey eveyone, im new to the forum, and i have a situation. like an idiot before reading up on it i decided to put a blow off valve on my 2002 WRX. and of course a couple of days later i last a huge amount of power. so today i took the aftermaket BOV off and put the stock one back on for good. ive bee driving around for a couple hours now and i still feel an EXtreme loss of power, its almost feels like my turbo is nonexistent. will it take couple of days for the power to come back or is there something else i need to do. thanks for any comments
    Check for leaks, and consider re-setting the ECU and maybe using Shiv's method (search here) for quick learning.
    Dec 2006
    thank you for the info, how would i go about resetting the ECU. im pretty new to this so im trying to absorb as much info as possible so feel free to throw it out there
    Oct 2002
    The Old Folks Home
    Here's the link to the Shiv quick learn trick. It tells you how to reset the ECU in the first step.
    Re-Mapped ECU Learning Trick 10-20hp in 5 seconds :)
    Moving to Maint. Serv., Troubleshooting.
    --Ray
    2013 Subaru BRZ Limited
    2002 Subaru WRX Bugeyebrid Wagon
