Is over filling oil bad?
Results 1 to 4 of 4
This is a discussion on Is over filling oil bad? within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I just changed the oil. Put in about 4 1/2qts and when I went to check it today after driving ...
    Registered User darksft's Avatar
    Nov 2006
    NJ
    I just changed the oil. Put in about 4 1/2qts and when I went to check it today after driving around doin a little shopping the stick was reading low. Then I put some more oil in it and now it's way over the full line. What do i do now and did I damage anything. The car was running fine so I haven't noticed any change. Please help a noob out.
    Apr 2006
    Sioux Falls, SD
    It can be. If the crankshaft is splashing around in the oil, the oil will foam and you could get air in the oiling system, which is never a good thing.
    You should always wait a few minutes after you shut the engine off so the oil will drain back into the pan so you don't get those false readings.
    My water heater has a blow off valve.
    Registered User RealDealTarheel's Avatar
    Dec 2006
    Hubert NC
    Too much oil can also blow seals, not a good time.
    Apr 2004
    Southeastern PA
    Moving to Maintenance, service, troubleshooting, and basic repair ...
    Mods & Pics
