I f you climb under the car fromt the passenger side you will see it not on the first half of the Dp but more towards the rear of the exhaust but not to far down.
This is a discussion on help locating second o2 sensor within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; where on the dp is it and how do you get to it, under the car or through the hood? ...
where on the dp is it and how do you get to it, under the car or through the hood? thanks
2005 WRX Wagon stg 1 - 3/12 to present
1996 BMW 328is coupe - 5/11 to present
02 WRX wagon stg 2 - history
WTB: Cobb Accessport ap-sub-001 for 2005 WRX
I would highly recommend acquiring an 02 sensor socket to remove it. Makes the job a lot easier, IMO. The times I've needed one, I just used AutoZone's rental program. You get all of your money back when you return the tool, so it winds up being free.
--Ray
Proud owner of a N.E.R.D.
**** off with your candy paint jobs and spoilers that are 8x too big , I say never be complete, I say stop being perfect, I say let... lets evolve, let the chips fall where they may.
i had to use a 22mm wrench to get it off, jacked the car up and cranked as hard as i could until it turned, you dont need any special tools if a skinny white chick can get it off with a wrench, i only used one spark plug anti fouler though because there is not enough room to put the two on there, there was a heat shield or some type of undercover in the way, after unplugging the battery for 30 mins, the light went off and hasnt come on yet (keeps fingers crossed that one was enough)
well the thread i had for instructions mentioned the crow foot tool for removing spark plugs but napa didnt have any in stock so since i cant get a socket wrench on there i just used a 22mm hand wrench and all went fine, i dont think much could go wrong loosening it with a hand wrench vs. the crow foot tool (or whatever you call it)
