Results 1 to 4 of 4
This is a discussion on Air Bag light within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; i just installed a Boost Gague and it is monted where my clock was, but now my Airbag light is ...
    Aug 2005
    Vernon CT
    Air Bag light
    i just installed a Boost Gague and it is monted where my clock was, but now my Airbag light is on is this a common problem? i have an 06 wrx.
    Thanks
    Nov 2006
    Richmond, Va
    Could be something that was done wrong during the install. Was the neg terminal taken off the battery before this was done?
    http://svt4u2try.com | Myspace | Photos
    97 Cobra, 98 Z/28 hardtop
    Moderator   Sasquatch's Avatar
    Apr 2004
    Southeastern PA
    First post? Greetings and welcome to the club!
    I would check the wiring in the areas where you were working. Sounds like something may have come loose.
    Please stop by New Member Hangout and introduce yourself.
    Moderator for: Aftermarket Vendor & Installer Review / Detailing Forum / Engine Modifications / Exterior & Appearance
    New Member Hangout / Off Topic / Tri-State
    Mods & Pics
    Check the fuse.
