Results 1 to 7 of 7
This is a discussion on First oil change....got ?'s within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hey guys I'm about to do an oil change and had some questions first so i don't screw it up. ...
    Registered User darksft's Avatar
    Nov 2006
    NJ
    Hey guys I'm about to do an oil change and had some questions first so i don't screw it up. First of I have a stock 05 WRX with the 4EAT and 32k on the motor. I've heard you have to pre-oil the filter. What does that mean exactly? I'm goin full synthetic mobil 1. Also are there any other tips I should know changing the oil in these cars? It may sound stupid but this is the first turbo car I've owned so I don't know how different it is from a N/A car when it comes to the oil. Thanks for the help.
    Registered User LIV 2 RLY's Avatar
    Jun 2006
    Central NJ/ Bethlehem, PA
    Make sure you remove the plastic undertray. It really isn't much different at all from my old Honda Civic. Just remember to remove and replace the crush washer, I have had one leak on me because I didn't change it.
    As for pre-oiling the filter, fill the filter about 1/2 way with oil and oil the gasket on the oil filter. Make sure the old gasket isnt stuck on the mating surface for the filter.
    let us know how it works out, I am lucky that I'm so skinny I can change the oil without jacking up the car!
    Registered User clemsonteg's Avatar
    Dec 2006
    are you changing the trans oil or the motor oil?
    Registered User blahblah's Avatar
    Sep 2003
    Chi-cago
    i think its also recomended that you do this after the car has been driven. I usually go for a short drive, then wait about 30 minutes for the car to cool down enough that I can do the change without burning myself.
    282 AWHP...267 lb-ft torque.
    2005 WRB WRX Sedan
    "he's a domestic fan with a hunger for rice"
    Nov 2006
    NJ
    Finally done. The car came with a 3 guage pod that has oil temp and the drain plug has a wire on a swivel head coming off it. I've never seen a drain plug so big in my life....I had to go out and search a couple of stores for that size wrench. I couldn't get a subaru oil filter so I got something else. Once I got the plug off it was a breeze. Thanks for the help.
    Moderator   Sasquatch's Avatar
    Apr 2004
    Southeastern PA
    I take the WRX for a 20+ minute drive and only wait for the time it takes to get the plastic skid plate off and the tools and drain pan ready. With care I never had a problem with burns.
    Moving to Maintenance, service, troubleshooting, and basic repair ...
    Moderator for: Aftermarket Vendor & Installer Review / Detailing Forum / Engine Modifications / Exterior & Appearance
    New Member Hangout / Off Topic / Tri-State
    Mods & Pics
    Dec 2006
    Quote Originally Posted by darksft View Post
    You had a safety wired drain plug. That car must have seen the track some.
