Engine block gasket leak
Results 1 to 4 of 4
This is a discussion on Engine block gasket leak within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; A friend of mine with an '04 STi just got his car back from the dealership about a month or ...
    Registered User VVVV's Avatar
    Sep 2003
    Denverish
    A friend of mine with an '04 STi just got his car back from the dealership about a month or two ago for warranty repair of his 6MT synchros. Now the car is leaking oil from the gasket between the two halves of the block. Has anyone seen this kind of failure? Will it require a full rebuild due to the crank bearing location between the block halves, or could he just torque all the studs and hope it stops?
    It's worth a shot to torque it down but there's no guarantee. Are you sure the leak isn't from the mating surface of the gearbox to the block (IOW either left over gear oil or a motor oil but from the rear) since the gearbox has just been off?
    EDIT: The more I think about it, the less I can understand how this could have happened. You're sure about the source, eh?
    Sep 2003
    Denverish
    Oil is pooling under and to the right of the throttle body. The dirty path leads back to the flange between the block halves in front of the pitch stop. IMHO, it's too far forward to be gear oil. All hosing and fittings up to the intake manifold have been removed and checked for leaks. If it isn't coming from that flange, I don't know where else it could be. I'm mainly worried about the condition of the bearings if there's been any movement between the block halves.
    With my anti-SOA/stealership bias, I can imagine how it happened, but I'd rather not go there.
    Is there any chance, even state lottery odds or worse, that they pulled the IC when removing the gearbox to improve access from the top, and they just made a mess? I have never seen this type of failure and am trying to find a simpler solution.
