Code issues
Results 1 to 7 of 7
This is a discussion on Code issues within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I'm throwing code p0037. By reading what other says it just an emission code. But I'm experiencing Engine Stuttering. When ...
    Registered User hakira's Avatar
    May 2004
    Slidell, La
    Code issues
    I'm throwing code p0037. By reading what other says it just an emission code. But I'm experiencing Engine Stuttering. When I clear the code It runs great, responsive and smooth. But Once I turn off the car and restart it, the code is back and causing the engine stuttering.
    The only other code I'm throwing is AC refrigent very low.
    Any suggestions?
    02' WRX OSECUROM STG 2 93OCT on 91OCT map -13.708 SEC / 097.84 MPH / 1.86 60 ft @ No Problem Raceway
    02' WRX OSECUROM STG 2.5 93OCT- 12.9 SEC @ No Problem Raceway
    Mods
    Aug 2005
    Winchester Virginia
    hey bro im havin the exact same issue..... istart to stutter at around 5600k and up.... i have no idea wat it is.. my boost is fine the vaccuum is fine and the fuel filter is clean... and i even changed my spark plugs... im clueless at the moment...
    Oct 2004
    Westchester Cnty, NY
    One, stop clearning codes. You need to diagnose the issue, not just turn the light off.
    P0037 = Rear oxygen sensor heater circuit malfunction
    You might need to replace the sensor since your car is getting older.
    2008 Satin White Pearl WRX Sedan w/ Navi
    2005 San Remo Red WRX Sedan w/ VF34 (traded)
    Pi Kappa Alpha | New England Flat 4
    Registered User VVVV's Avatar
    Sep 2003
    Denverish
    The good news is that's the cheap O2 sensor. The bad news is that the rear O2 sensor does not control operation, so the stuttering is likely not being caused by the bad rear sensor.
    More info please. UTEC logs? Any other pending codes? Any recent work done or changes? It kind of sounds like the car is pulling timing. Bad gas?
    Oct 2004
    Quote Originally Posted by VVVV View Post
    +1 I thought it might be the new winter gas that everyone is starting to get. But then, ive never had a cel (**knocks on a freaking red wood**) misfire for winter gas.
    Quote Originally Posted by D0WNxSH1FT View Post
    The original poster is in DE not US though, right?
    May 2004
    Slidell, La
    One, I'm not that retarded. Right after I posted this, I ordered another rear O2 Sensor.
    -I'm awaiting for installtion hardware from TurboXS for like 2 weeks now so no logging. I'm just going with Enginuity Tuning now anyways (just waiting on tactrix cable)
    -Like I said in my post only other code I'm pulling is AC refrigerant very low (don't remember exact code number). The P0037 is under Stored and Pending codes.
    -Recently installed PLX M300, IC hoses and PWR TMIC. Now I talked a buddy of mine who said that the TMIC should be fine to drive casual w/o tuning, while I waited for my hardware. I kinda thought this what might of caused the stuttering but I assumed the ECU should be able to adjust for the change.
    Yes I live in Germany.
    Mods
