Gas Smell
Results 1 to 15 of 21
This is a discussion on Gas Smell within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; First off...CHEERS!! I haven't been on here in some time (since I got married). Second, I've got a gas smell ...
    Amarillo, TX
    Exclamation Gas Smell
    Second, I've got a gas smell comeing from under the hood...especially when the fans kick on. This only happens when it's cold outside too. I moved from Amarillo Texas (higher elevation and colder temps) to Fort Worth Texas where it is much warmer but still gets cold (it was in the 20's last night).
    So, I guess my question is this...have any others had this issue? It's a pretty strong gas smell, and it'll creep into the car if you have the AC or Vents on (of course). I took it to a Subaru Dealership and a local shop I know and neither could find any gas leaks. I looked under the hood myself and under the car. I can't find any spots or smells directly. I can only smell it when it's cold outside and when the fans are kicking it up (or into the car trough the vents).
    I really don't know what to do. Hoping some others have had this issue and might be able to give some advice or maybe reference someone that has some knowledge on this kind of issue.
    -Terry
    Oct 2002
    Underground Particle Accelerator
    If you search for 'gas smell' you will find lots of threads on this. The 02's had a technical service bulletin released for a possible fuel leak when cold:
    http://www.scoobymods.com/forums/showthread.php?t=2886
    Experience has varied - I just got this today for the first time (it's ~25 out right now) and I don't see fuel, just smell it. Some people have seen a puddle of fuel on the engine block.
    I'm going to see if I can get a longer hose on the metal lines without taking off the intake manifold - I'm getting Perrin lines soon and don't want to have to work on this twice.
    Nov 2006
    Richmond, Va
    Yup, I have seen this before.
    http://svt4u2try.com | Myspace | Photos
    97 Cobra, 98 Z/28 hardtop
    Registered User osirissirhc's Avatar
    Sep 2006
    Glenwood Springs, Colorado
    i am having this same problem right now it just started a few weeks ago also when it get really cold out.... one morning i started my car and jumped under the hood really fast to look at my fuel lines to see signes of leeking and sure enough it starts to come out at the rubber section of line that lead to the cylinder on the drivers side most front..... woundering if you guys know how to go abouts fixing this issue ???
    Chris-
    05 STI- APS CAI, Apexi T-timer, BFG G-Force KDWs, Turbo XS catless turbo back, Perrin Crank Pulley, OPEN ECU tune, new ACT clutch kit and lightweight Flywheel
    13.6sec 1/4mile at 5,285ft elevation not on new clutch and FW
    BLOBEYE SYN...... #188
    Registered User SpeedWrx's Avatar
    Jul 2006
    California
    do you have a catless downpipe?
    Boba Fett BrianH's Avatar
    Oct 2003
    Way up high.
    Subaru released a TSB on it, good luck getting it fixed. The intake manifold has to be pulled in order to do it.
    Sep 2004
    Moline IL
    mine is doing the same. I'm waiting on the parts to come in to fix it. It's $100.00 for the 2 pieces. the tsb number is 09-36-03
    Good Luck
    Brian
    Rev'n Seven Motorsports And Quad City Boxer Four
    02 WRX Wagon 13.6@99mph 1.90 60 foot
    Registered User dcpatters's Avatar
    Sep 2004
    Irvine, CA
    This thread may be useful. I suppose now the cold weather is covering most of the country, this problem is occurring. Have noticed several posts on the subject. Anyway, one member claims not having to remove the manifold.
    Really strong smell of gas.
    2008 Evo X GSR. Custom tuned, Works panel filter, Intercooler pipe upgrade, TBE.
    Oct 2002
    That was me. In order to fix it the way the TSB says, then yes, you have to pull the manifold. I have a Perrin turbo inlet hose - I just pulled it off and had easy access to the rubber lines. I replaced the rubber with longer lines and double clamped both ends. The clamps that are on there are crazy loose from the factory...
    Sep 2006
    nope i still have the stock uppipe with the cat
    Chris-
    Nov 2006
    Richmond, Va
    Yes there is a fix and a TSB on it. We did one the other day that solved the problem.
    Nov 2006
    South Jersey
    Sorry to dig up an old post, but I had the same problem with my car. I complained to the dealership enough times, and SOA is covering it under my classic warranty, so its costing me $50 to have the TSB done.
    Sep 2004
    Moline IL
    I was able to fix mine and it wasn't a fun job. It took me 10 hrs to do the job, and regret not taking some where to get it done
    Later
    Brian
    Registered User SwisSlesS's Avatar
    Jun 2006
    Cambridge, MA
    Quote Originally Posted by JaredRS View Post
    I'm going to the dealer today to have the TSB repair done and I have every intention of getting the cost covered under warranty. I'll let you all know how it works out (my mother's a lawyer so that will probably show up in the conversation at some point ).
    Oh, and what was the $50 charge for? I want to have as good references as possible for when I go in.
    Nov 2006
    South Jersey
    Quote Originally Posted by SwisSlesS View Post
    The $50 is the deductible I have on the classic warranty.
    Good Luck!
