Results 1 to 15 of 19
This is a discussion on PLEASE HELP FAST! E-Brake freezes up???:unhappy: within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; Hi everyone, I had to miss work today because of my dumb E-Brake freezing up. Second time this has happened ...
    Registered User Proj.JDM_STI's Avatar
    Nov 2006
    Hi everyone, I had to miss work today because of my dumb E-Brake freezing up. Second time this has happened to me. So I was wondering if anyone has had their E-Brake freeze up and become stuck from the cold weather? And how can i fix this problem???? I already maintenanced it from the first time it happened, and thougt everyhing would be good now but aparently not. Any suggestions? Thanx for any Help
    Nov 2006
    Bump
    Registered User Robman7835's Avatar
    Jan 2006
    York PA
    Carry a wheel chock(sp?)....seriously though i wouldnt know how to stop it from freezing...if i had to guess though, it is a cable system so maybe lubing the cable could be a solution?????
    PSM Bugeye..Cobb Stage 2
    Nov 2006
    yep it is a cable system......how would i lube the cables?.....they are wrapped in rubber to protect them and i don't really know how to take them off....anyone know how to lube em'?
    Nov 2006
    i have already lubed all the e-brake parts in the rear rotor's on both sides...but couldn' see how it would be posible to lube the cables and thougt what i did the first time around would work.....now i just need to know how i would go about lubing both cables....Anyone?
    Jan 2006
    York PA
    It requires a special tool called a "cable luber".....it looks like this
    Nov 2006
    how's it work?
    Jan 2006
    York PA
    You unhook the cable from one end and put this over top of it....it creates a seal over the cable end when you clamp down the handscrew....then using a lube with a straw you spray it in the desided hole on the tool and it forces the lube down the cable inside the isulation....it'll make more sense when you actually have the tool at hand and your trying to connect it to the cable.....my old streetbike had a super stiff clutch cable and i went out and bought a kit that came with the tool and lube for like ten bucks and it worked like a champ...
    Nov 2006
    Cool sounds like it'll work, but we'll see. Thank you for the tip.
    Jan 2006
    York PA
    No prob.....i hope this works out for you......
    Nov 2006
    Oh one more thing where to buy? That'll save me the time for looking cuz i really need my car
    Jan 2006
    York PA
    I would just look at you local auto store like autozone or advanced auto parts...they should have it........i got mine at a local cycle shop so i cant say for sure if they will have it or not.....
    Nov 2006
    Cool thanx again
    Jan 2006
    York PA
    ok i had no luck at autozone or advanced auto with the online search......check a local motorcycle shop....they for sure will have one
    Nov 2006
    our avatars are almost the same btw lol...nice car
