There is a lever on the trunk latch mechanism that disables the remote release. Do you have the owners manual?
This is a discussion on 3 minor things that annoy me a bit how to fix?... within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; first the rubber sheath thing on the drivers side window near the mirrior has a minor hole in it, but ...
first the rubber sheath thing on the drivers side window near the mirrior has a minor hole in it, but it makes a loud blowing noise with the window up.
The passenger side rear window switch doesnt work, the driver can roll the window down, and the passenger can roll it back up but it wont go down.
Lastly the trunk release level stopped working. It just stopped, my friend threw a box in the trunk slammed it down a bit excessive (he didnt expect it to be so light) and since then it will not open with the release lever, you can open it with the key but thats the only way.
If anyone could suggest how to fix any of these Id appreciate it.
2003 Hyundai Tiburon GTV6 (sold)![]()
2002 Subaru Impreza WRX
Moderator for: Aftermarket Vendor & Installer Review / Detailing Forum / Engine Modifications / Exterior & Appearance
New Member Hangout / Off Topic / Tri-State
Mods & Pics
The windows are a common ground system through the master(driver's door) switch. If only the pass rear switch isn't functioning, it is probably that door's switch. I would check the switch's harness is properly connected w/ no obvious loose wires or damage before just throwing it in though.
Dirty Jersey
Part-Time Grammar Nazi
RIP- '02 PSM Wagon
08 Candy White MK5 GTI 6spd
Moderator:Tri-State and Transmission & AWD forums
