ramps
Results 1 to 14 of 14
This is a discussion on ramps within the General Maintenance, Troubleshooting & Accidents. forums, part of the Tech & Modifying & General Repairs category; I going to be changeing my oil soon and i just bought some ramps for when i work under the ...
    Registered User siverscoob's Avatar
    Jul 2006
    NH
    ramps
    I going to be changeing my oil soon and i just bought some ramps for when i work under the car and what not but when i change my oil and its on the ramps will all the oil come out or do i have to jack up the back of the car.
    Chad - NEW ENGLAND F4
    04 WRX Stage 2 soon
    Q RayfieldsWRX's Avatar
    Oct 2002
    The Old Folks Home
    Most of the oil will come out. You'll probably have a tiny bit "stuck in the corner" of your oil pan towards the back.
    I just put the driver's side front up on jack stands, just enough to give me working room. That tilts the car in the direction of the drain plug, so I think I get most of it out.
    --Ray
    "Bro ima get Bimota BB3 because expert. My parents have 911 turbo but awd won't let me launch, ima get 962 twin turbo Group C bro." -- SD_GR
    2013 Subaru BRZ Limited
    2002 Subaru WRX Bugeyebrid Wagon -- SOLD
    2002 Subaru WRX Sedan -- SOLD
    Registered User afbluesv1k's Avatar
    Apr 2006
    Buffalo, NY
    The oil plug is on the back of the pan, just drive it up and pull the plug, there is still oil old oil in the pump and turbo lines so all the oil never comes out anyways.
    Just be sure to prime the new oil filter with oil before you put it on. Put the rest of 4 quarts in, back it off the ramps onto level ground, shut off car, and check oil level and add accordingly.
    Oct 2002
    The Old Folks Home
    Quote Originally Posted by afbluesv1k View Post
    "back of the pan"? Mine's on the passenger side of the pan. Your point is valid, though, a DIY oil change isn't going to get it all out of there.
    --Ray
    Jul 2006
    NH
    Thanks for the input
    04 WRX Stage 2 soon
    Registered User Darrell's Avatar
    Sep 2004
    Indy, IN
    What kind of oil change is going to get all of the oil out? None of the instant oil change places do anything more than what we would do in our own garages. Nor would any other general mechanic.
    Mine: '05 PSM WRX 5MT Sport Wagon, Cobb AP
    Wife's: '05 SRR 2.5RS 5MT Sport Wagon
    The Knack. It's a rare condition characterized by an extreme intuition about all things mechanical and electrical ... and utter social ineptitude.
    Oct 2002
    The Old Folks Home
    Quote Originally Posted by Darrell View Post
    I believe that there are some devices that actually "suck" the oil out, and I didn't know if perhaps they got more out.
    As stated, though, there's bound to be oil left in the lines and pump that's just going to be there no matter what. Nothing to get excited about.
    --Ray
    Apr 2006
    Sioux Falls, SD
    You guys use a ramp?
    My water heater has a blow off valve.
    Registered User bikefreax's Avatar
    Jan 2006
    Columbia
    Just got finished doing mine this morning along with changing the IC hoses to Perrin silicone ones. I use ramps and have no problems at all. Just a pain to get the splash shield off to get to eveything.
    '05 WRX Wagon San Remo Red, Stage ?????????????
    Aug 2006
    Lake Zurich, IL
    it is not neccessary to jack up the car at all to do an oil change just do it on level ground and you should be fine.
    Registered User TheFugitiveMind's Avatar
    Jul 2005
    Ventura County,CA
    ^yeah but if your car is lowered it may be a bit hard to stick your head under the car and take off the skid plate and access the drain plug and filter..........
    2006 Aspen White STi
    Stage 2 Open Source Road Tune
    A bunch of bushings from TiC
    Oct 2002
    The Old Folks Home
    Quote Originally Posted by TheFugitiveMind View Post
    Yep, the lowered car thing is the only reason why I jackstand one side up a bit.
    --Ray
    Apr 2006
    Buffalo, NY
    Well ok rear of passenger side, mine is an 02 sedan. As far as ramps, black poly/plastic ramps from the auto store work great. Done in 10-15 mins.
    As far as oil in the motor, the oil in the pan, and filter is where all the contaminates go, so the 1/2 quart of lost oil in the motor will be displaced at a rate of 9:1 so it wont hurt it to stay in there. Any method of trying to remove all the oil will cause more of a problem with the pump, and turbo not being primed on initial startup.
    Jul 2006
    NH
    my car is lowered thats why l bought some ramps, last time i change my oil it sucked trying to get to everything. But i was just thinking that if the car wasent level i might not get all the oil out of the pan.
    04 WRX Stage 2 soon
